Screen keeps minamizing and go to taskbar on screen
    Sergeant:
    Champion:
  • 214 Answers
Check the keyboard keys whether any key(s) got stuck and also check the mouse
Posted on Oct 13, 2008
Bar keeps going away
Do you mean the taskbar? Right-click on any empty spot on the taskbar, select "Properties," then deselect "Auto-hide."
Sep 09, 2013 | eMachines Computers & Internet
I need 2 minamize my screen
Just go to the Desktop - Desktop Assistant - Control Panel - Display -and adjust the settings it should give you the option to keep or return to the past settings
Jan 15, 2013 | Acer Revo Computers & Internet
Move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
I cannot see the bottom part of my screen on my hp mini 110. How can I adjust the display? Am using windows 7
right click on the screen go to personalize then display settings and in that dialog box there should be an option to change screen resolution by the sounds of things you have the wrong ration so try different settings until it works.
If you are scared to change any of the settings don't worry a message comes up after the change to ask if you want to keep it that way, if you click nothing it reverts to the way it was.
Mar 04, 2011 | HEWLETT-PACKARD HP Mini Netbook / Intel...
I want to change the position of task bar from vertical to horizontal.
In order to move your taskbar to different sides of the screen, first right-click on the task bar and un check "Lock the Taskbar".and drag it in the direction that you want. When you have it positioned, right click and select "Lock the Taskbar" to keep it where you have it set
May 18, 2010 | Computers & Internet
I minamized a window, and now I can't get rid of it.
assuming that u r a professional, check the size of virtual memory..try increasing..
unload some unnecessary software..
do a through virus scan using a licensed and updated antivirus (i prefer avg/kaspersky)..
probably ur ram/hdd is faulty or small in size..replace with a standby n see..
also check for defective capacitors on the main/mother board..
reinstall os..
the above often take place with some error message(s)/blue screen..
but if there's no such displaying, esp if hangs/stops/power off during installation, it may b caused by the main/mother board or even the battery..
..contact ur system admin/vendor....
Oct 27, 2009 | Dell Inspiron 1525 Notebook
In vista: taskbar does not show icons of opened files
it might be your taskbar is on auto hide try this
Show or hide the taskbar gl_icon_tip.png Applies to all editions of Windows Vista.
The taskbar is usually located at the bottom of your screen. It looks like this:
getopencontent.aspx?assetid=984f8561-57a1-4b9c-9f22-f0d8dddec294&documentset=en-us&renderkey=xml Taskbar
You can hide the taskbar to create more space. If you don't see the taskbar anywhere on the screen, it might be hidden.
Hide allShow allHide all gl_arrow_down_static.gif To show the taskbar
• If the taskbar is hidden, point to where you last saw it to show it again. If you can't remember where you last saw it, try pointing to the bottom of the screen first, and then to the side or top of the screen, if necessary. You might need to move the pointer almost off the screen to show the taskbar.
gl_arrow_down_static.gif To hide the taskbar
1. Open Taskbar and Start Menu Properties by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
2. Clear the Lock the taskbar check box.
3. Select the Auto-hide the taskbar check box.
The taskbar is hidden from view. You can see it again by pointing to the place where you last saw it.
gl_arrow_down_static.gif To turn off auto-hide
2. Clear the Auto-hide the taskbar check box.
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
My whole taskbar is not visible
If you move the mouse pointer to the very bottom of the screen, the taskbar should pop up as it does when you press the Windows Button, but without Start. If you want to keep it up, right click on the taskbar and select "Properties" In the new window, "Unselect" "Autohide" and the taskbar will stay up.
Jun 11, 2009 | Microsoft Windows XP Home Edition
Black screen on emachine c2881
3 things. If you hit the windows button does the taskbar show on the bottom? Also, right click in the middle of the desktop and click on "Personalize" (Vista) to change the screen saver and see if that fixes your problem. Assuming you can see the "Start" button, do the following: Right click on Start, click Properties, click on the Taskbar tab and make sure the box is checked next to "keep taskbar on top of all windows"
Apr 25, 2009 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
