Question about Singer Sewing Machines
Singer 281- thread will not go through upper tension discs
The thread is either resting on the outside rim of the upper tension discs (resulting in no tension) or it goes in between the discs (like it should) and it gets locked in tight. No amount of pulling on the thread will get it to pass. The foot is up when I try to pull it. Turning the knob has absolutely no effect either way. Everything is threaded right, the lower tension is o.k., etc.
It is a refurbished machine that I just bought, and the first time I used it, it locked tight like this. I took it back and they literally messed with it for a little while, and it worked, but they didn't know what had gone wrong, or what they did to fix it. But it worked, so that was o.k. So I took it home, and it worked fine for several days and a lot of sewing. But all of the sudden it does what I just described in the first paragraph. I would really like something to suggest to the guys in this wee little father & son repair shop, because I don't think they'll know any more the next time when I bring it in.
Thanks-
  • caya123 Oct 13, 2008
    Thank you so much- I did check all that before, and it was definitely stopping at the upper tension discs. I know what you mean about it being wrapped around the spool holder- that's a good thought. Sometimes it gets caught in the little notch on the spool itself, too. But that wasn't it.
    I think maybe it was lint or a piece of thread caught in the discs?? I took the thread out and blew on it & generally messed with it- and finally got it to work!! Till next time- but maybe that was it? Is that a possibility? Thank you again!!
  • 323 Answers
You need to find out where the thread is binding.To do this:
Remove the thread from the needle and pull on it, next remove the thread from the take up lever and pull on it( By the way, all of this should be done with the foot in the UP position). Remove the thread from the tension and pull on it. Remove the thread from the thread guide and pull on it. Remove the thread from the guide with a hole in it, if there is one. Keep doing this all the way back to the spool of thread until you locate where the thread is hanging up. I think you will find the thread is wrapped around the spool holder but I've been wrong before. Good luck.
sewman7
Posted on Oct 13, 2008
  • John Free Oct 13, 2008
    A piece of lint in the tension would only make the tension loose, not tight. Disassemble the tension assembly(diagram it) and look for grooves or rough spots on the tension discs. You may have to replace them or the tension itself.
    If at all possible,use large cones of thread not small spools. They cost much less and will give you less trouble.
    sewman7
My singer futura xl580 will not sew at all shows error 06 in display and no its not upper thread problem
Are threading your machine with the presser foot UP? It is the only time the thread can get between those tension disks, and if it's not there (or if the thread is only on the outer rim) it will trigger the "thread out" sensor.
Feb 23, 2017 | Singer Sewing Machines
Singer touch ironic 2005 getting a huge tangle of thread on the bottom as I am sewing. This is not resolved by removing and replacing the bobbin.
Usually, a thread nest or bird nest, is a result of an upper thread issue: misthreading, thread not seated in the tension disk, upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point between high & low number. Then retest.
Jan 09, 2017 | Singer Sewing Machines
New singer plus one.....constantly stopping with message top thread broken (which it is not) but there is a nest of thread from the spool underneath...have rethreaded from spool and bobbin # of times
bird nesting of the bobbin thread is a result of the needle thread tension not tight enough
increase that tension up and the message may be eliminated
Nov 20, 2016 | Singer Sewing Machines
Singer facilita 9858-1 top thread is winding around the bobbin case. It seems to get caught under the bobbin case retaining plate, around the left side of the case,& under the rim of the posi
try cleaning cleaning the tension disks, remember you tension setting,, take some unwaxed dental floss and go between the disc's to clean in them, and then reset the tension disc's by to normal
Dec 10, 2014 | Singer Sewing Machines
Singer 2112
first ,re thread the upper bobbin, check the needle to match the fabric and the lower bobbin thread should be the same like the upper thread. If it dose not work, clean the discs tension for the upper thread.
Aug 15, 2014 | Singer Sewing Machines
Haven't had the Singer Sew Simple very long. Second time to use it. Ready to throw it out the window. Bobbin tension seems to be off. Thread keeps knotting up and breaking under fabric, jamming the...
Have you tried re-threading it? Remember to keep the presser foot up as you thread so that the tension discs are open. Re-thread the upper thread because it can often cause bobbin jams.
Perhaps your tension discs are blocked, try running a thicker thread through by hand to clean them.
Check there are no broken threads in the bobbin raceway.
Sometimes the wrong size needle upsets the tension.
Sep 15, 2011 | Singer 3116 Simple
Singer inspiration. When using zipper foot. Excess amount of thread on bottom of material, very loose and loopy. Wasting alot of thread for such a some task.
Your top threading is not right, check to make sure that your thread hasn't jumped out of a guide. Totally rethead with the presser foot up, now pull thread, it should move smoothly, next put the presser foot down, the thread should barely move. This will seat your thread in the tension discs. If, that does not work, insert a new needle.
Apr 23, 2011 | Singer Inspiration 4210 Mechanical Sewing...
When sewing on my machine, the stitches look fine from the top but when I turn the fabric over, the thread that came from the bobbin is in loops. And If you grab that thread , you can pull all of it out...
Please make sure your upper thread is threaded correctly, more importantly it sounds like there may be a build up of lint or dirt in between the upper tension. Prise the discs apart and remove any lint and make sure when you thread the machine that the needle thread goes right in between the tension discs and does not just sit on the outside of them. Hope this helps you.
Oct 10, 2009 | Singer Sewing Machines
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Sewing Machines Logo
97 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
