Question about Garmin GPS
I have a Garmin nuvi5000. Instruction book says "Unit will energize when auto key us turned on" I can't get mine to do this. Must turn on manually.
  • 171 Answers
The vehicle power cable is designed to plug into the suction cup mount. If this is not connected in this manner, the unit will not power on automatically as to prevent power surges.
Posted on Oct 13, 2008
Hi, my air handler, when the thermostat is on auto will usually turn on but sometimes it doesn't. When the thermostat is set to "on" it always comes on. This has happened with 3 different thermos
Im willing to bet you have a bad relay or sequencer that energized the fan. If it periodically works when in auto im sure this is your problem. If you have a wire landed on the G terminal you should have your tstat set up as electric heat OR tstat energizes the fan rather than gas OR equipment energizes the fan.
Jan 15, 2018 | Heating & Cooling
As we needed this unit on our trip south, turned on the unit and all we got for the entire trip was "loading maps"
you may need to connect it to your computer and up date the data mine went down and that fixed the problem
Feb 04, 2011 | Garmin nuvi 1390T Car GPS Receiver
On my Garmin GPS, There is no letter "L" on the
I have this GPS and mine shows H and L, so you must have a unit with a program error. contact garmin support
Nov 04, 2010 | Garmin nuvi 250W GPS Receiver
The screen displays a vertical group of black and grey lines. Won't shut down?
it seems like its in calibration mode
Turn unit off
Slide Power Key to the right ( lock )
Hold your finger on the screen for approx 30 seconds until calibration screen appears
Follow on screen instruction''
Here is a online Manual for your unit that I found .... http://www.retrevo.com/pdf/23127ci168/76/Calibrating+the+Screen#q=Garmin+285WT
Oct 28, 2010 | Garmin Nuvi 285WT GPS Receiver
How to perform a factory reset on a Garmin GPSMAP 172
The model number of your unit has been cut off so I can't find exact instructions. I found a page here where the guy said he held down Enter and Page keys while turning the unit on.
http://forums.groundspeak.com/GC/lofiversion/index.php?t128887.html
You should be able to find the user manual if you do a google search. It will have all the details.
Try "Garmin Gpsmap <your model> manual pdf" as the search string. (no quotes of course)
Hope this helps
Aug 16, 2009 | Garmin GPS
My garmin edge 305 powers down as soon as i press the mode butto
I had the same problem after a rainstorm. Although the unit is supposed to be waterproof, it was not. Garmin replaced the unit when the mist did not clear after a few weeks, and the unit never worked after that.
Jan 03, 2009 | Garmin Edge 305 GPS Receiver
NEW Garmin 205W Use of Apple Mac USB for charging Causes malfunct
Hold the power button to the left for approximately 15 seconds, then release it. It should reset the unit and turn ON. It happened to me before and it worked.
Dec 08, 2008 | Garmin nuvi 205W GPS Receiver
I have a Nuvi 200w that I received last December as a gift. This unit takes forever to aquire a satellite. The "DIFFICULY AQUIRING SATELLITES" message comes on 90% of the times I try to use it....
While under warranty.... yes.... Make sure it's been registered on their site before calling them and requesting an RMA number.
- Jim
Sep 17, 2008 | Garmin GPS
GPS Logo
50 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
