Cable modem 315
Im having some trouble with some different types of modems RCA DCM 315 I'm looking for he scamatic power supply because it doesnt turn on.
  • 1 more comment
  • j_guillot Oct 13, 2008
  • j_guillot Oct 25, 2008
    I still cant find an answer for my problem Im still trying to fix the RCA cable modem 315, But they're off at all times it doesnt turn on. Its not a power supply problem, its the actual modem.
  • 535 Answers
Take your modem on nearest electronic store they will gave you same votlage of power supply of your modem
Posted on Oct 13, 2008
  • sandip panchal
    sandip panchal Oct 24, 2008
    take your modem on nearest electronic store they will gave you same votlage of power supply of your modem
    Sergeant:
    Champion:
  • 435 Answers
Hi, Any 12V DC of about 750 mA with a similar pin like this should be fine.
http://cachepe.zzounds.com/media/quality,85/brand,zzounds/fit,400by400/DNPRKPWA1-0bdb4ca99dc1c1528aefaa6141887696.jpg
I hope this is what you meant by power supply scheme.
    Brigadier General:
  • 6,966 Answers
To my understanding:
  • Your concern repair cable modem(s) particularly RCA DCM315.
  • Your requirement schematic diagram of power supply.
  • The main issue, modem will not power up.
The power supply of most (but not all cable modem) is a wall adapter. Common output is 12 volts at about 1 ampere. The basic design is a small transformer, bridge or fullwave diodes and a capacitor. Newer designs uses an SMPS type. To my understanding, an RCA RCA DCM315 uses a similar adapter but not 12 volts @ 800mA. Internally, basic cable modem regulates the raw power from the adapter to 1.2, 3.3 and 5 volts. Most (but again not all) would be using a single chip CX24943 IC. This IC triggers the LED illumination. So, it may be that the cable modem is receiving power and regulating it, but if this IC will not trigger the LEDs, then in appearances, the modem will not power up making the problem not a power supply issue..
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Oct 25, 2008
    Hi again,
    Your post on Oct 25 " Its not a power supply problem, its the actual modem".
    My post on Oct 13. "the problem not a power supply issue". Pls confirm if the RCA 315 uses an CX24943 IC If yes, have you checked for the presence of 1.2, 3.3 and 5 volts ?
    Sergeant:
  • 208 Answers
I hope the link given below will be useful........It has user manual and troubleshooting steps too........
click here
If the above doent solve the problem.....I request you to give a brief description of the problem....
Waiting for the comments........
    Genius:
  • 1,124 Answers
This are your model data
RCA DCM315
MODEL NUMBER: DCM315
STANDARDS
DOCSIS 2.0 Compliant
Field Upgradeable to 2.1 SW
RECEIVER
Downstream Modulation: 64/256 QAM
Frequency Range: 88-860 MHz
Channel Bandwidth: 6 MHz
Maximum Upstream Data Rate: 27/38 Mbps {64 QAM/256QAM}
RF Input Sensitivity: +15 to -15 dBmV
64 QAM:>23.5 dB, 256 QAM:>30dB: BER 1e-8
Input Impedance: 75 Ohms
TRANSMITTER
Frequency Range: 5-42 MHz
Upstream Modulator: QPSK/16QAM
Mainstream Upstream Data Rate: 38.00/38.00 Mbps (QPSK/16QAM)
RF Output Level: +8 to +58 dBmV
Automatic Level Adjust
Gain Control Range: 50 dB
Frequency Stability: ±5 kHz
Output Impedance: 75 Ohms
SOFTWARE FEATURES
Software Downloadable
Protocol Filtering: Ethernet & IP
SNMP Management: V2, V3
Security: BPI
LED Diagnostics: 5-Step LED
http Server (CM status)
SPECIFICATIONS
Dimensions: 5 4/5" H x 2 7/25" D x 6" W
Approx. Shipping Weight: 4 Lbs.
Operating Temp.: 0 to +40C
I/O INTERFACES
Ethernet 10 Base-T or 100 Base-T: RJ45-Autodetect
RF Connector: F-Type
Number of PCs Supported: 32
USB Port, OS Supported - Windows: 98SE, 2000, Me and XP
USB Port, OS Supported - MAC: OS8, OS9, and OS10
User Switches: On/Off & Reset
Your power supply model Number
SY-09080-17 Power Supply for RCA DCM315 Modems
Your compatible products
http://www.broadbandproducts.com/network_powersupplies.html
You can buy one here:
http://cgi.ebay.com/RCA-DCM-315-Digital-Cable-Modem-Stop-Renting-Plastic_W0QQitemZ200257152620QQcmdZViewItem?_trksid=p3286.m20.l1116
    Genius:
  • 1,550 Answers
Have a look at the link below for basic troubleshooting techniques for RCA modem
Troubleshooting DCM 315
I accidentally knocked the AC adapter to my RCA DCM425 Cable Modem AC out of the wall outlet while at my computer desk. After plugging it back in, the lights on the modem flashed on momentarily, then shut...
You could have only a damaged power supply, please look in an Eectronics parts store another with the same characteristics (input and output voltage,current, plug type) and retest, maybe your actual AC adaptor is broken inside and that's why it doesn't power up your modem correctly.
Feb 19, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Comcast is my service provider and I have had an RCA DCM 245R modem for almost 10 years. Until recently it has worked fine. On an ever increasing basis I am losing internet connection and when I look at...
It can be an issue with the modem or with the line. When the line drops the link then the modem shows only two lights. And, when you power cycle the modem (unplug and replug it) it establish the session again with the comcast.
So, i'll suggest you to get the line checked first and if comcast finds that line is working fine then get the modem replaced.
Rashish
Aug 15, 2010 | Thomson RCA DCM245R Modem
How do I lock my modem using password?
You open up Internet Explorer and type in your i.p address, example : 192.168.0.2, you can normally find your i.p address in network connections, and open the internet connection up, and click on details and your i.p address should be there. once you are on your ip address settings, click wireless settings and then there should be security options, and then you can put security on.
Reply back if this doesnt work.
Thanks.
Jul 18, 2009 | D-Link DCM-202 Cable Modem - RETAIL...
Can't get Linksys wireless router & RCA DCM 425 to work together
ok, ur old modem was configured for those two devices to work to gether
so u have to do the same here
*have ur modem connected directly to ur comptie
*go to ur command prompt if u have vista ( start * search * type cmd)
xp (run then type cmd)
the type in the screen that poped up ( ipconfig) enter
*look for default gateway type that in ur browser address
*should take u in ur modem interfase go to (advandced | PPPlocation | then set that modem on
BRIDGE MODEM and the modem should restart then connect router that should do it
GOOD LUCK
,July
rate my service please
Apr 11, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Is my modem a WiFi router?
This RCA DCM 425 is a cable modem only its not even a router, its just a plain cable modem that is being provided by some cable company like Cox and Comcast, try searching again for a different box there they have a brnad name of Linksys, Netgear or Dlink because those are the common manufacturer of wireless router ...
Hope that helps............
Sep 18, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
No connectivity from 1 laptop but connectivity with another`
Try resetting the modem whenever you change between those PC's some NIC's will hang a cable modem stuck on an address.
May 02, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Rca cable modem...
This one is for a DCM 315, it should be pretty close and might work. http://a1212.g.akamai.net/7/1212/6718/20030131/comcast.download.akamai.com/6718/help/cmdrivers/RCA_315.zip
Jun 20, 2007 | RCA Cable Modem DCM315R (11603540)
Computers & Internet Logo
614 people viewed this question
David Payne
David Payne
