Question about Whirlpool Washing Machines
The belt on the washer broke it is a whirpool GHW9400PL4 I have the back off and do not see how to tension the belt
  • 750 Answers
Hello ctwconstruct
Welcome
You said, the belt on the washer broke it is a whirlpool GHW9400PL4 you have the back off and do not see how to tension the belt
At this site you will find all the diagrams on the left side of this page which you can scroll down on and click the one you want to see enlarged .
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504601
Happy to help you.
let me know how you do!
Huuum,
Please remember to leave a rating!
Posted on Oct 13, 2008
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Top load Kitchenaid washer KAWS850LQ wont spin. Took off back, found broke belt. Best way to replace belt
    It won't spin without the belt. You need to place the belt from the motor to gearbox and there may be a tension pulley. Most are adjusted by loosening the motor and pulling it tight
    Dec 02, 2014 | KitchenAid Washing Machines
    How do i replace the drive belt
    If you tip the washer back, you should be able to see the drive belt on the bottom of the machine. Chances are, the belt broke and didn't just fall off. I would suggest taking the old belt (which you'll find there on the floor) to an appliance store and have them match it up with a new one. Installation is fairly straight forward. It will go around the motor, transmission pulley, the water pump, and a tensioner (if equipped.) I hope this helps! :)
    May 01, 2014 | Kenmore 24032\24036 Top Load Washer
    Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
    I can not find your model number that you posted.
    I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
    Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
    Hey bud, i replaced my kenmore washer with a new coupler, but still it will not spin??
    inspect under the washer. look at springs for broken or one that may have come loose. inspect drive belt for broken or off pulleys. the drive belt is not turning pulleys, belt maybe broke or outa pulley grooves. or belt tension springs are broken or unhooked. good luck!!
    Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
    Belt came off tensioner, and tensioner off unit.
    Here is the tensioner diagram you need, for most any dryer.
    http://www.applianceaid.com/images/belt-config.JPG
    First clean and lubricate the axel of the wheel with some spray silicone. Try not to get it on the wheel outer surface.
    Then locate the slot in the bottom of the cabinet floor. The wheel should line up with the drive wheel at the end of the motor shaft.
    Place the tang of the tensioner in the slot.
    Press the wheel wayyy back passing a loop of the belt BELOW the tensioner wheel and loop it over the end of the small drive wheel.
    Release tension on the tensioner and the wheel will pull it taught.
    Aug 13, 2009 | Whirlpool Dryers
    My daughter is in Sechelt , BC and is driving a 94 Explorer. The tensioner pulley broke off from the bracket and was lying on the engine. As I can't physically look at it (she sent me pictures), it ha
    honestly just replace the tensioner. its a complete unit. Unless you have the bolt and washer for the bearings are not bad then, just bolt it back and make sure it spins freely
    Apr 12, 2009 | 1994 Ford Explorer Limited
    Fitting the belt to the hoover 5050ed
    nope,, but
    all dryers are generically the same
    remove the front panel and door
    pull the drum
    loop the belt around the drum, at apporximately the wear marks of the old belt
    reinsert the drum
    loop the belt around the motor pulley
    pull the tensioner pulley hard against the spring to the end of its travel
    loop the belt around the tensioner pulley
    allow the tensioner to move back under spring pressure to tension the belt
    rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
    reinstall front panel & door
    26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
    breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
    Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
    Oct 01, 2008 | Whirlpool LER4634J Electric Dryer
    Washer belt
    To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
    May 14, 2008 | Amana NAV5800A Top Load Washer
    Washing Machines Logo
    77 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
