Question about VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09)
K7vm3 mobo RAM
Hi, i just wanna know if this guy's telling the truth or not.
does this mobo have to have the "low density" RAM?
or can i get by with the less expensive high density RAM......
thanks
  • 928 Answers
If you are referring to the ASROCK mobo then it will work on the high density although not as good as with the low density but it will nontheless work.
Posted on Oct 13, 2008
Pc ddr memory what is the difference between high density and low density
you need to check with board to fine what ram works with first.i use what they say to use so no problems later and save money as well ok jim
Nov 25, 2011 | Computers & Internet
Hi guys, i have installed 2 sdrams pc-133 512mb,together 1gb, but yhe bios and the system shows me only the half memory,whyyyyyyyy
Are you sure that both sticks of RAM are properly "seated"?
How much memory is found when only one stick is used?
How much memory is found when only the other stick is used?
Which motherboard? Some very-old motherboards only support a maximum of 256MB per slot.
How many memory-chips are on each stick of RAM?
If you have purchased "high-density" memory (small number of memory-chips),
and your motherboard only supports "low-density" memory, then only 1/2 or 1/4 of the actual RAM will be used.
Feb 17, 2011 | DFI CA63-EC Motherboard
My computer is hanged if i installed d dynet ram in my pc.
It may be the fact that, although you've got the correct type of ram, you've bought the cheaper high density ram and your pc will only run on low density ram.
Remove said ram and log on to the Crucial and/or Orca websites, both are reputable and they have a scan function.
This will tell you exactly what type and how much ram your pc will take.
You don't have to buy from them, but the info is good and the ram would be guaranteed.
Nov 15, 2010 | Computers & Internet
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
When starting up stops in middle of setup screen or bios
Do you hear a posting beep??? if so and you have a video card, remove reseat it and retry, also do same with ram.
If no posting beep then do as above, if still no go it suggests faulty ram / cpu / mobo.
Mar 05, 2010 | Asrock K7VM3 Motherboard
How can i know if a ram suits my Legend QDI
you got to options
1. following the indications of your motherboard documentation (recommended/best), if you need to find out details about your motherboard you can possibly download and use one of this tools to get info about your motherboard and possibly find the manual online in the manufacturer's website
2. the following page will check your system to find out what memory you have and what you need and up to how much you can go http://www.crucial.com/promo/index.aspx?prog=uslp_intel_fbdimm
3. checking on ebay: in the following links indicates that it should be low density:
Module Size: 512MB
PC133 SDRAM
UNBUFFERED
Non-Ecc
168 pins
3.3 Volt
Structure: 64Mx64=512M
Low Density: 2 Banks of 32Mx8
SPEED: 133MHz
CAS Latency: CL3
hope this helps
Nov 22, 2009 | QDI Group QDI Advance 10T Motherboard
Planning to upgrade my RAM(motherboard K7SOM + V7.5C). Ram have high & low density. What is the difference? Which suit my motherboard? Thanks.
Look at the sticks of RAM -- "high" density means fewer chips on each side of the stick, i.e., newer technology and production methods have packed more bits into each chip, while "low" density usually means 8 chips/side, using older RAM chips.
Older motherboards do not expect to find "high" density RAM, and typically will only detect 1/4 or 1/2 of the RAM on the stick.
If you buy a new motherboard, it will support BOTH densities.
Oct 22, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
How do I determine what kind of memory that I need?
Go to Crucial.com and install their configuration utility through your browser. They will tell you what you have and all the combinations you can do to max out your system. Look at the specs of the RAM and you can get it from Crucial or some other vendor.
Dec 30, 2008 | Computers & Internet
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Installing new memory
ya cuse old moduel is slower hu drops speed back to 2700 and not 3200 ? corect its in bios settings re auto detect ram set to automatic config itself what brand ram u buy sum fox commm bords very picky on low denstiy and hi density styles ok low beter more compatble 38 bucks 1 gb on ebay ddr 400 i run 3 of those in my gigybyte moby and it loweres my ram spee dto 333mhz not 400 when i use all the slots up cheak your bios settings let me know name brand usally the pp who make it call them tell thenm and ask for time settings to be best with your mobo ok if they have great tech support if not tell me models
Jan 17, 2008 | Foxconn 760GXK8MC-RS Motherboard
VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09) Logo
208 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
