Question about Texas Instruments TI-83 Plus Calculator
Turn-on woes My TI83 will not turn on. Batteries new and installed correctly. What gives? Khumalo
  • 1 more comment
  • ngondo Oct 14, 2008
    Hi-
    Calculator came on for a split second then went off again! Repeated procedure 3x,still no dice.
    Ngondo
  • roby718 Oct 16, 2008
    I was attempting to install baos and then after i tried the installation procedure it will not turn on and I NEED IT FOR SCHOOL. please give me a solution I am literally vibrating i am so upset, this is similar to what i felt like after a delivery truck removed the side of my car at 70 mph!
  • toadster13 Nov 30, 2008
    new batteries...will not turn on...zero.
Take out the AAA batteries and hold the on/off key for thirty seconds. Replace the batteries and it should come on. If it doesn't remove the backup battery and the AAA batteries and hold the on/off key for another 30 seconds. Replace all batteries and turn it on again.
Posted on Oct 14, 2008
For the baos problem, just remove a battery, leave it out for about 5 seconds. Before replacing it, hold the del key. Replace the battery while holding the del key. The calculator should turn on and display: "Waiting... Please install calculator software now." Connect it to your comptuer and install the TI-83 Plus OS.
Posted on Nov 11, 2008
My TI83 won't turn on. I just put in new batteries
Having gone over a month without a response to my query, I assume my suggestion to change the screen contrast solved the problem.
Sep 01, 2011 | Texas Instruments TI-83 Plus Calculator
My nex tech binoculars will not turn turn on . Batteries are good
Was the camera dropped??
If it wasnt dropped try changing the batteries.
install a new or fully charged battery/batteries into the camera.
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Cameras
When I put new batteries in the TI83 plus calculator i get the message RAM CLEARED. You have to push very hard on the buttons to get a number to register but it does give correct answers. Any idea why I...
While trying to fix a problem with my calculator I came across this reset process. It might help you... http://www.ehow.com/how_5121373_reset-ti-plus-calculator.html
Jan 07, 2011 | Texas Instruments TI-83 Plus Calculator
Texas instruments TI-83 Plus won't turn on. I have replaced the AAA batteries.
Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] till it darkens enough.
If that does not solve the problem here is what the TI Knowledge base has to say. Please read till the end. I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If that does not solve the problem, you should contact Texas Instruments at ti-cares@ti.com or www.ti.com/calc.
Nov 09, 2009 | Texas Instruments TI-83 Plus Calculator
My TI84 Plus will not turn on, even with new batteries. I have tried both faces, and it will not turn on
The Texas Instruments FAQ area of their web site has on such question answered. You may want to read the relevant article. Scroll down the page and look for the part on the TI83/TI84 Plus family.
Hope you will find the answer to your calculator's woes.
Oct 30, 2009 | Texas Instruments TI-84 Plus Calculator
My TI-84 Plus Silver edition will not turn on. I have tried new batteries and everything, but it just does not turn on. Is there a way to reset it or something although the calculator does not turn on?
Here it is from the horse's mouth (TI Knowledge base)
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 21, 2009 | Texas Instruments TI-84 Plus Silver...
Wont turn on when new batteries were installed
It is likely that the calculator is ON, but the screen is too light to enable user to see anything. If that is the reason, you can darken the screen.
Press the [2nd] key and release it. Press and hold the UpArrow till screen darkens enough.
If that does not work, here is what the Texas Instruments Knowledge Base says about the calculator not turning on.
I hope it helps.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
Oct 20, 2009 | Texas Instruments TI-84 Plus Calculator
I changed the batteries and now it will not come on
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create backup using TI Connect™ first.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83 or TI 84 Plus family to reinstall the calculator operating system (see below.)
Reinstalling the OS for the TI83/TI84 Plus family
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TIConnect installed on the computer.
Hope it helps.
Oct 11, 2009 | Texas Instruments TI-84 Plus Calculator
My Ti83 silver edition will not turn on.
I'm not sure if this will help you patchesb7; it sounds like your calculator is having issues :(
This will help others whose calculators suddenly won't turn on anymore, even after changing the batteries.
Note:
This will return the calculator to the way it was when you got it out of the package. Any data or programs have stored since will be lost.
Step 1: Remove all four AAA batteries.
Note: You will have to hold down the CLEAR button while doing Steps 2 and 3. Do not let go until after you have pushed ON in Step 3. I found this easiest to do by holding the calculator upside in my left hand with my pointer finger holding the CLEAR button so the ON button was easier to access.
Step 2: Hold down the CLEAR button (located under the arrow keys) and reinstall the AAA batteries.
Step 3: Press ON button and then let go of both buttons. The screen should say the RAM has been cleared. Press CLEAR to continue.
Aug 24, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
304 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
