Question about Sony Cyber-Shot DSC-P200 Digital Camera
Lens will not come out at all
My lens will not come out when you turn the camera on at all how would you solve this problem
  • 489 Answers
Hi
If your lens is jammed then it needs to be cleaned, repaired or replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help!
You can also buy a defective camera online and use the parts to fix one from the two yourself.
Good luck from Darntoothysam com
Thomas
Posted on Oct 13, 2008
My Canon Powershot SD 980 IS has suddenly given me a lens error camera restart message. I have changed batteries, called Canon, used compressed air, try restarting with a/v cable etc. Whassup with that. It...
Hello and Welcome to FixYa!
Sir/Ma'am Lens error is because of several reasons and there are several solutions to fix up the Lens ErrorYou have tried One of the most common solution which Fix up the lens error like lens error is solved by removing the batteries and replacing it with a new set of fully charge ones, or Lens error may also solved by compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or Lens error also mostly solves by Insert the cameras Audio/Video (AV) cable, and turn the camera on.
You have tried all these but but problem is still there so problem is quite complicated, well i am suggesting you some more solution which may fix up the Lens Error:-
First of all if your camera allows you to work for minute then try finding and selecting the "factory reset" option to set your camera back to its original factory condition. On some Canon cameras, this requires holding the menu button down with the camera powered on for up to 10 seconds. However note that a lens error might sometimes override the reset option, and thus the option might not appear. So if you find the option then by resetting your camera to Factory Setting may fix the problem
If problem is still there then Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time, This may also solve the problem
Mostly Lens Error is also happens when Lens Barrel is out of position so Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots and it may fix the problem
If problem is still there then there are some other solution too which remove the lens error but all of then are technical and if you try to follow them you enter into the realm of potentially damaging your camera. There is definitely some risk in them, So i recommend that if your camera is still under warranty, before trying any of these, please please first contact your camera's maker or service provider. It will solve your problem quite easily.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind or if your camera is out of warranty and you can try some risky solutions.
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 02, 2011 | Canon PowerShot A460 Digital Camera
I dropped my fujifilm finepix av100, the lens is now stuck and will not go back in when i turn off my camera. when i turn on my camera it says ''turn camera on and off'' but it doesnt solve the proble
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
Nov 17, 2011 | FUJIFILM FinePix AV100 Digital Camera
Camera lens cover won't open when you turn the camera on. Says "power off then on" but still stuck
This kind of problem occurs if camera dropped on floor that broke lens mechanism OR lens mechanism got dust particles that make it stuck.
Usually lens mechanism needs to be replaced to solve the issue, however, user level try to solve the problem is to tap camera on your palm a few time gently that may release stuck lens mechanism and it start working again, if that does not help then lens assembly will be replaced.
Thanks.
Jun 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
When we turn on our Sanyo VPC E1090 digital camera the lens does not appear to come out completely & we get an "lens error 0x0311" message on the screen then it turns off. WHAT IS WRONG!! ...
If lens does not appear to come out completely and camera gives error that means lens mechanism got broken internally and lens assembly will be replaced to solve the issue.
Lens replacement is not user level repair and local camera repair shop[ will do this job for you if camera is out of warranty.
Thanks.
May 28, 2011 | Sanyo VPCE1090 Digital Camera
Camera says turn off and turn on panasonic lumix dmc-fs5
While you are turning the camera on, hold the lever which you use for zooming in. The lens should extend before you get the annoying message about turning the the camera off and on. Then, gently apply pressure to the lens as if you wanted to push it back to the camera. While you are doing this, turn the camera off (lens should come back into the body of the camera). This will solve your problem.
Thank you!
May 17, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Problem with the lens-cap
turn on the camera and then hold it upside down and after just tap the lens with your hand slowly,try that solution
Dec 09, 2009 | JVC GZ-MC500 Memory Card Camcorder
I have a samsung L100 camera, my lens got stuck and the camera would not turn on, I pushed the lens in while turning the power button on, the lens came out and the camera is now functioning, only the...
you've misaligned the lens barrel I think. there's not much you can do to solve this short of a repair, which generally outweighs the price of the camera, due to the insane price of the individual parts. You can try realigning the lens barrel by doing what you did the first time.
Apr 25, 2009 | Samsung L100 Digital Camera
Lens jammed
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 22, 2009 | Kodak EASYSHARE M1063 Digital Camera
Digimax 430 camera won't turn on
If your lens is open and the camera turns off after those dreaded beeps, I have a fix for your problem. Basically, for this model of camera, the lens first pushes out a bit and then it retracts into the camera. Well, my lens got stuck on the pushout and it prevented the camera from turning on. I used some finger pressure and wiggled the lens a bit. Then I turned it on and it retracted to where is was supposed to be to take pictures. Then I turned it off and it retracted into the camera. Problem solved!
Nov 05, 2007 | Samsung Digimax 430 Digital Camera
Sony Cyber-Shot DSC-P200 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
