Trouble started by shooting out more than one sheet. Solved that by keeping only one sheet in printer. Now the sheet only starts thru, stops and computer and printer each, say paper jam. There is no paper jam. Ivan Armstrong
  • iarmstrong24 Oct 13, 2008
    Canon PIXMA MP460
    Sergeant:
    Champion:
  • 200 Answers
Hi
Turn off the printer and then turn on...
thank you
Posted on Oct 13, 2008
  • 6,487 Answers
Can you please provide us the brand and model of this printer so we can help better...
Paper jammed but sheet came out with corner shredded...assume piece(s) stuck in printer but cannot see it...followed manual's trouble-shooting guide but printer will not print...keeps showing error code...
If you aren't willing to disassemble the printer, and you are unable to see the missing pieces of paper, you will need to have the unit serviced or buy a new one.
If it's under warranty, don't say anything about the shredded paper, just tell them that it started with this error code one day, and you have no clue what's wrong.
Feb 26, 2011 | Canon Pixma iP6600D InkJet Photo Printer
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
I have an HP PHOTOSMART C4680!On the screen it apears "Cartrigde problem" and the button is blinking!What can I do to fix the problem?
1.Remove the ink catridge
2.Replace properly
3.try to print
4.if even same problem will be occured then replace with new catridge.
Note: Hp printer come along with a software cd.it has the driver for printer,troubleshooting and maintenence software.in the trouble shooting guide will help to removes and replaces the catridge properly.Also a Quick start guide(A printed sheet) also can help.
5. if Even the problem not solved then unsqurew the printer squrews carefully ,
6.look at the mechanisim if any damaged
7.look any Data cable or Power cable may be damaged (Cables are looking like a white color mica ribbon)
Thank u sir ... All The Best....
Apr 22, 2010 | Office Equipment & Supplies
False "paper jam" signal prevents printing: My HP 2210 had been working fine. Suddenly, when I try to print, the paper starts to feed for a few inches and then stops. I get a "clear paper jam" error...
it's probably due to what i would call the print head blocker ( on your left handside of your printer head) that is broken . check it out! it also responsable to control how far goes the sheet before start printing.
Jan 14, 2010 | HP PSC 2210 All-In-One InkJet Printer
Dell 946 printer has been working for over 2 yrs with Dell computer. Today computer says can not communicate with printer. Will not print from any program. Ran thru trouble shooting, disconnecting USB...
reinstall the printer driver and check the printer spooler started or not........... to start print spooler go to start...>run..then type services,msc then enter..>it will open a window....>open printer spooler service and restart it.....................
Nov 02, 2009 | Lexmark X6170 All-In-One InkJet Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Having trouble with paper jams all day
Very lightly rub a wet cloth on the top half of a heavy A4 size paper (100g).
Insert this sheet with wet side in first facing upward. Open MS Word and hit Ctrl + P. It will print a blank page on the wet sheet. When it tries to pull this sheet hold it with your hand but don't try to pull it too hard. When it stops pulling the sheet then load another one (dry) and see if it solves your problem. Perform these steps very carefully and I may not be held responsible for any damage. I recommend this because it solved my problem.
Aug 04, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Printer will not feed card stock
Sorry. I have not solved this problem and I cannot afford to pay anything for your services.
May 01, 2009 | Epson Office Equipment & Supplies
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
jasbo
jasbo
