Question about Kenmore Oasis HE 27082 Top Load Washer
F code What does the f code mean on my washer?
    Novelist:
    Champion:
  • 261 Answers
Machine off press and hold for a count of 5 the spin button and release for 5 until 88 appears. If a F error comes up write back for a solution
Posted on Oct 15, 2008
Unimac. Why is it displaying E FL and won't spin?
Unimac Washer Product Support ' ManualsOnline.com
laundry.manualsonline.com/support/unimac/washer/
Unimac Washer uw60b20u80001. 0 Solutions ... on start up unlock door light stays on.display sa. Unimac ... washer has falt code E FL what does this mean and.
E fl error code on industrial uni Mac washer. What's it mean ...
www.fixya.com/support/t20744713-e_fl_error_code_industrial_uni_mac
Jan 07, 2016 | Washing Machines
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Kenmore Elite He washer code "OE"
The 0E code means the washer won't drain. It is usually a problem with something obstructing the pump, a kink in the drain line or the pump is burned out.
Jul 26, 2014 | Whirlpool Duet GHW9150P Front Load Washer
It shows a LE code
Hello.
The code showing at the front of the screen of your washer means the below explanation.
The L means LOCK and while the
E means ERROR.
However what the washer is saying is that you need to lock up the door of the washer properly then the problem of the LE will be solve .
Thanks.
Nov 08, 2011 | Washing Machines
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
What does a 3E error code mean? i have a maytag
Trouble shooting guild for this machine indicates this means Motor Failure. Over current is detected
Feb 08, 2010 | Maytag MAH8700A Front Load Washer
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Duet washer code f 33? What does it mean?
the fault code indicates that your main data cable from the controller to the motor has miss-comunicated: unplug the washer wait about 30 minutes then plug it back in and, let me know if the code clears
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
