Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
When I turn the power on on my Peavey blazer 158 guitar amp nothing happens. Is there a fuse?
    Problem Solver:
  • 16 Answers
Hi I have written two troubleshooting guides on the issues you have try them at http://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
Let me know if you still face a problem
Posted on Dec 13, 2008
Peavey tnt 115 blowing fuses
your either overloading something cause that's what pops fuses. My guess is that what your plugging in or into has a ground issue. I'm wondering if it does it with nothing plugged in at all. I would say if you have nothing in and it does it, you need to find where the ground issue is. that's my best guess
Feb 20, 2014 | Peavey Electronics Peavey Tour Tnt 115...
How to fix a gt5 peavey rockmaster amplifier
Hi. My name is Danielle and I have a peavey rockmaster GT-5 guitar mini amp, and it can work with/without the cable. I lost the cable and I didn't need to worry because the amp still worked as long as it had good batteries. But, after about 4 months of no use of it, I put in a brand new battery and the light wouldn't turn on. I looked all over the amp to see if something was missing but I found nothing. I'm really not sure what to do because this is a very good amp and I'd hate to throw it away. Can anyone Help Me?
Mar 24, 2012 | Peavey Electronics Peavey Rockmaster...
Peavey Rage 158 guitar amp
I don't believe there is a power "outlet" on this, only an "inlet".
Usually the inlet will have a lead, often green, that goes to the chassis.
There will usually be two other wires, often black and white that connect to the other two pins.
From the back of the connector, with the center pin tied to the grenn wire of the triangle lower, the pin to the right should be the white and the pin to the left is the black wire
Jul 24, 2010 | Peavey Kb2 1x10' Keyboard Amplifier
I have a peavey classic 20 guitar amp that works as normal when switching on but after a couple of minutes the power amp tubes (EL84's) just switch off. What could the problem be?
What do you mean they "switch off"??? If the heaters in all the tubes go out, check the fuse for the heaters, F2 and its fuse clips/holder.
There really is nothing in the circuit to make them "switch off"
If the heaters in the EL34's "switch off", the other tubes should go out as well.
Jan 25, 2010 | Peavey Music
What kind of fuse does peavey pr15 passive use
Here is a site that has PR15 fuses... shown as a 2.1 amp. Very strange value, and it must strictly be for the tweeter portion as 2.1 amps is nothing for a speaker... I don't know that I believe this site.
If you have a Guitar Center near you, inquire there.
Dec 28, 2009 | Peavey Music
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
Change the voltage from 240v to 120v
Unless there is a 240/120 switch on the back, this amplifier cannot change voltage. The only way is to replace the power transformer, and when you do that you need to use the exact model transformer Peavey uses for the 120 version. I have also seen differences in handling power outside of just a different transformer for USA/Euro models.
The differences between these two market models might be beyond what is cost-effective to convert.
If it is the Peavey blazer 158, they go for as cheap as 100 bucks here in the states. Or buy one new for 120.00 bucks and 4.99 shipping: http://www.dcmusicstore.com/Peavey-blazer-158-guitar-amplifier
Best advice: sell it for what ever you can get and buy one here.
Hope this helps!
-mike
Mar 28, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Dead peavey supreme XL amp head
I'm not a pro on amps but I have a Peavey Rage 158 amp, I'd suggest seeing if the speaker itself still works by directly connecting a source onto the speaker[take the wires off and hook it up to a source].
Try turning it on and checking the wattage going to the speaker wire, then follow the wire back and check the big coil with copper wire among other things.
A common problem with old amps are the tubes, check the tubes to see if they are burnt out [google it if you need a guide]
then check on ebay or maybe an electronic/guitar store.
If that didn't help, reply with more details
Good luck.
[If you don't want it ill take it off of you for $20 :p ]
Feb 01, 2008 | Audio Players & Recorders
Car Audio & Video Logo
225 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
