Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
RLT-5030AH LINE TRIMMER HOW TO PUT LINE ON SPOOL?
I have tried to put new line on the spool and it never feeds thru, it has a division thru the middle of the spool and i am unsure how to wind new line on to the spool. The instruction guide just says to wind in that direction not how to wind on with two sections so that it will feed correctly.
  • 50 Answers
You need to prepare two lines of the same length. Wind the bottom one first. place the end of the line in the slot provided. Wind the second spool and place the line in the opposite slot. feed the lines through the two holes provided, be careful to allow the lines freedom. Insert the spool checking to see that the lines do not get pinched. You are now ready to GO!
Posted on Jan 03, 2009
Need instructions on changing the spool on electric grass trimmer/edger
Turn the trimmer over, I put it in my lap.Remove the orange spool cap by squeezing with thumb & forefinger. It will come right off. Remove & discard(there has got to be something they can be recycled as?) If you are right handed, hold the new spool firmly with left hand with flat side with the arrows up, keep a firm grasp & use small needle nosed pliers(I use hemostats) etc. to free the loose end of the line where it is looped thru the 2 slots. Keeping hold of the spool so it doesn't all unwind, let enough out to feed thru the hole on the side of the compartment where the old spool was. 2-3" will be enough. Then, place the spool into it's compartment with the flat arrow side up.Keep a good grip on the spool until you get it into place. Replace the spool cap by aligning it in the 2 slots that it came from & gently squeezing again until it locks into place & you are set to go. Don't worry about feeding the line out to proper length, it will do that all by it's self.
Aug 03, 2013 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
How to load spool
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, hyh
Jan 30, 2012 | Garden
Why is line feeding out too fast on 503a
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 29, 2012 | Garden
How do you replace the cutting line
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 11, 2012 | Ryobi Garden
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
How do you remove the line feed to replace with new. Is is scred on or does it have a lock washer
It should be screwed on. There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 17, 2009 | Craftsman Convertible 25cc. Gas Line...
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
Load new line onto the mighty vt26 17" curved trimmer
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How to change the string
Jim
Adding trimmer line to spool on husqvarna trimmer-two strings
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 19, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
380 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Roland W VanLue
Roland W VanLue
EugenesDIYDen
EugenesDIYDen
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
