Question about Refrigerators
Refrigerator Water tastes Moldy - already changed filter
Help,
Whirlpool side by side refrigerator with water and ice. Was fine for a few months and then the water started tasting moldy. Changed the filter and it still tastes moldy.
What do I do?
Meg
  • 6 more comments
  • bowljam Nov 02, 2008
    SAME exact thing happened to me. With a brand new samsung fridge. changed filter and still tastes bad, like bleach or chemicals...toilet water :)
    confused...
    tap water has no silmilar taste. Fridge water and ice was great for 2 months, then ...yuck
  • SYDNEY ADDLEMAN Jan 18, 2009
    I HAVE KENMOOR REFRIGERATOR SIDE BY SIDE WHICH I BELEIVE IS WHIRLPOOL, MY FRIDGE COMPRESSOR BECAME FAULTY WHILE I WAS AWAY, AND NOW MY WATER ALSO TASTES MOLDY, I HAVE ALSO CHANGED FILTER, AND AFTER RUNNING OFF A COUPLE OF GALLONS IT TASTES OK, BUT AFTER BEING LEFT TASTES MOLDY AGAIN , THE PROBLEM MUST BE IN THE WATER LINE, BUT I AM NOT SURE, ANY BODY GOT ANY IDEAS ???
  • Anonymous Feb 19, 2009
    I have a similar situation. I bought a brand new refrigerator and used it for about a month. Then my family went on vacation for about 7 days. When we came back the refrigerator water and ice had a metallic taste to it.
    The house I bought the refrigerator for is brand new (Nov.2008) so none of the water lines are old.
    I don't see how I could need to flush them because the water tasted fine for the first month. Now when I dispense all the cold water out the bad taste goes away.
  • Anonymous Apr 06, 2009
    I have also the same problem. We have just purchased a new Samsung side by side fridge freezer and plumbed the water supply in. We have drawn off over 3 litres of water and it still taste funny. Mouldy, chemically etc. Can anyone help.
  • Chandralal57 May 04, 2009
    I wen thru the same problem. Change 02 new filters. Still the same. Looking for a resolution.
  • Anonymous May 09, 2009
  • Jungleman The Handyman Mar 28, 2014
    I changed my water line to a stainless steel brand. The water started tasting moldy. I changed the water filter, which was new, again. I flushed the system more than recommended. After a couple days the moldy taste was back. I am positive now it is the stainless steel line. I am going back to a plastic line. I recommend a Pex water line, Cross linked, high density polyethylene. I changed the water line to this and moldy taste was gone. Plus it will last longer than a Polyethylene line which needs to be replaced every 5yrs since the plastic becomes weak.
5 Suggested Answers
  • 57 Answers
SOURCE: strange taste in ice cubes
Did you use new water lines? If you did then clear the icecubes from the tray and use an appliance store cleaning solution to wash it out with. their solution is designed for fridge use and wont leave an after taste......Rinse well...... Also for awsome Ice......Install a large in-line water filter.... Makes mine taste like frozen mountain spring water with no nasty taste or smell. Hope it works for ya!
Posted on Jan 04, 2009
  • 103 Answers
SOURCE: Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The 596.xxx tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Posted on Jun 07, 2009
  • 9 Answers
SOURCE: Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Posted on Jun 23, 2009
  • 102 Answers
SOURCE: Sub Zero 650S with bottom freezer-Ice tastes funny(musty ? taste)
The 650 does not have a filter built into the unit. Any filter would be on the supply line to unit, usually in the basement below the unit, or under the kitchen sink. Do you use alot of ice? If not you may want to empty the bucket every few weeks to let it produce fresh ice.
Posted on Aug 05, 2009
SOURCE: my ice taste like plastic
okay so i had the same problem too but with both water and ice. What you do is if your refrigerator is new then the first 4 batches of ice discard, this is will get rid of the plastic taste. With the water get a big container and press the lever for 5 seconds then let it sit for 5 seconds then repeat for about 2 minutes. This fixed it for me and hopefully it fixes the problem for you
Posted on Aug 12, 2009
The water and ice started tasting very bad with a sulfur chemical taste a few months after the water filter was replaced. What should I do?
Did you recently have a water main break in your area about the time the bad taste started or any plumbing repairs in the house?? Could be the filter is contaminated. Try another filter and go from there. If problem is gone it was the filter. If still there---possible problem with refrigerator water system and tubing.
Mar 15, 2015 | Whirlpool ED5LHAXW Side by Side...
Whirlpool Side by Side Bad Water Taste
Most "new" fridges with water dispensers and ice instruct the consumer in there manuals to "bleed" the reservoir by running a couple of large pictures of water thru it. I usually recommend dumping the first few harvest's of ice as well (I believe this is also mentioned in most manuals too). once that is done the water should be fine as any contaminants in the system/reservoir should be gone. you may try changing the filter after this, but it shouldn't be necessary. most ice makers do not have there supply water travel thru the water dispenser reservoir however. the water filling the ice tray should have no baring on the water you dispense into a glass to consume.
hope that helps.
good luck
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Jun 23, 2009 | Refrigerators
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice tastes bad from ice maker
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Phil
Apr 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
My new Whirlpool Refrigerator the water and ice still stink
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Dec 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
2,705 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
