Speakers don't work. Used Dell Dimension 4550 with no setup guide. Don't know if speakers need power source or just plug into hard drive. Volume control is on. Louis
    Problem Solver:
  • 52 Answers
Depending on the speakers--if battery powered or powerpack--they need a driver to work--
you can do a hardware check to see if the speakers are found.
The speakers are NOT plugged into the hard drive..the are plugged into a LPT port that is plugged into the motherboard. The hard drive is the main unit that stores all the windows operational system functions, and software you install on it. This can not happen IF there is no motherboard that has the critical information to tell the hard drive to accept the information and where to send that information through the CPU (central prosessing unit). The drivers are the programs that make your speakers, printers, and any other hardware you add work. Now before the speakers can work the motherboard need a sound card and the driver to make that operational. So the sound card needs to be checked too. go to the dell web site for the drivers for the sound card if needed. www.dell.com
you also have a setting comtrol for your volume too. make sure the volume is turned on.
Posted on Oct 13, 2008
Dell dimension 4550 Bootmgr missing error message
you would have to removed the hard drive and possibly buy the external adaptor for your hard drive then plug it in to another computer via USB and reformat the hard drive..
Jul 09, 2012 | Dell Computers & Internet
Computer has no sound. Took hard drive to Best Buy. Geek said according to the computer, the sound card is ok, don"t know why there is no sound, oh and by the way you have a high fidelity sound card, and...
Yes you should be able to fix this. First do you have external speakers for this computer or is it internal? Next has this worked before and stopped working?
Aug 14, 2010 | Dell Dimension 4700 PC Desktop
I just got a used set of altec lansing ADA745 computer speakers and can't get power to them. I have never seen computer speakers w/ two wires for input to the computer. I plugged the usual green colored...
https://support.dell.com/support/edocs/acc/ada745/ada745.pdf
That is the setup guide for the speakers.
The two wires plug into a cable that then that single cable plugs into the computer, this way you have sound coming out of the left and right hand speakers.
Feb 05, 2010 | Altec Lansing Multimedia Computer Speakers
I need to hook speakers up to my Dell B110 computer.
2 things are needed to get sound from your speakers:
1-wiring connecting your speakers to a socket to the back of the computer. (The spot they need to plug in to ON YOUR COMPUTER is a small light green circular socket. The other end of the plug you plug in here should run to one of your speakers *usually the right side speaker-the right speaker should then have separate wiring to connect the left speaker.)
2- A source of power.
Some speakers use their own power source and plug in to a power outlet - your wall. Other types have a USB type plug and plug into a USB port in your computer and that is how THOSE get their power.
Those are the basics of sound setup. Some computers are equipped with more complicated setups such as surround sound, subwoofers, digital and more. Reply if you need more help, I will try to assist you further.
Hope this helps.
Feb 02, 2010 | Dell Dimension™ B110 PC Desktop
My dell dimension 8400 has no volume I tried new speakers and the volume is not muted how do i get it to work
Click on the speaker icon in the lower right side of the screen, and set the volume control to high. If no help, do you have amplified speakers? Line or headphone outputs are too low to drive speakers directly.
Sep 07, 2009 | Dell Dimension 8400 PC Desktop
Primary hard drive not found
since you already tried removing and reseating the hdds . The problem could be the motherbaord slot. To troubleshoot the same
1. First Disconnect all hardrives and optical drives from the system
2. Go to the system setup or BIOS
  1. Turn on (or restart) your computer.
  2. When the blue DELL™ logo appears, press <F2> immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again.
3. Hold down the ALT key and press "F"
4. Hit ESC , save changes and exit .
5. SHutdown the system
6. Reconnect the HDD IDE cable to the optical drive connector on the motherboard.
You can refer to the following motherboard diagram
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101668
7. Check if the hdd , is getting detected in the system setup
You can refer to the following link on how to read system setup screen
http://support.dell.com/support/edocs/systems/dim4550/syssetup.htm
Thanks
Proton
Jan 30, 2009 | Dell Dimension 4550 P4 Socket 478B...
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
Installing a new hard drive
XP SP 2 supposedly has no limitations on hard drive size so if you selected it to use the maximum available space during setup it "should" have picked up the entire drive. The only other thing I can think of is to make sure you are running the latest BIOS on your system, so you may want to check into that if you haven't already. I hate to say this but you may have to rerun the XP setup from your CD and make absolutely sure that the maximum partition size is selected and that it matches the size you expect it should.
Good luck and let me know how it goes. I'll continue to research and will let you know if I find anything of any help.
J
Feb 23, 2008 | Dell Dimension 4550 PC Desktop
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
