Question about DeLonghi MG15T SafeHeat Oil Filled Radiator Heater
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
Delonghi MG15T Magnum Oil-Filled Radiator -the timer is always running and the timer noise is irritating - we have to unplug it when off. I lost the manual...
  • 3 Answers
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Posted on Dec 19, 2008
No heat it all, it has oil but does not work set it on any heat settings but nothing doen not work
To find the problem you will need to pull apart the switch(s) and the thermostat and follow the power to see where it is stopping at...
if there is power to the element and no heat then your done the element is not repairable...
If you find the problem is in the switch or the thermostat, you may be able to find the needed parts here
http://www.nelsonappliance.com/space+heater+parts.html
heatman101
Jan 15, 2011 | DeLonghi MG15T SafeHeat Oil Filled...
Delonghi dragon oil filled heater with timer. How does the timer work, is there a way to set it so that it stays on all the time? Do not have the manual
Within the timer is a 3 point switch. Push the switch to the end closest to the arrow and away from the clock icon. It will stay on
Oct 04, 2010 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Delonghi HMW2400T oil filled radiator with no operating manual
if the timer is working when it gets to the off/on position you will hear a click so to test it just turn the timer around slowly until you hear the click much like an alarm clock that has the alarm turned off hope this helps regards Jim
Apr 14, 2009 | Heating & Cooling
Lost the manual
It is working properly. It is suposed to go off and on just like your house heater it is thermostat controled the higher the setting the longer it stays on till it reaches a certain tempeture factory preset
Dec 26, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
I need instructions for operating the MG15T heater
Basic ...set to desired heat setting...it will turn itself on and off to maintain that temp in room (This is made for small rooms)
Dec 12, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Need an instruction manual for DeLonghi Magnum MG15T
Here was the tricky part for me:
The round timer dial has red tabs on the outer edge of it. They all should be pushed inward to allow continuous operation.
From the manual:
Please note when you first use your heater, all the tabs are outwards. You must push in those
tabs for the period that you want the heater to work. (If you want to bypass the timer you must
push all 96 tabs inward).
I hope this helps.
Nov 16, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
DeLonghi MG15T SafeHeat Oil Filled Radiator Heater Logo
2,548 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
