Replacing capacitors in 62525
I have Mitsubishi 62525 and blinking green light on front panel. I read a lot of 4 capacitors to be replaced. Are there any instructions available how to get to the board. I opened TV's the back panel but have no idea how to get to capacitors.
Any suggestions?
    Scholar:
  • 98 Answers
Check out this link its not the same of your tv but you will get an idea of how to remove the board
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks
Posted on Oct 13, 2008
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking light
Have you tried the reset button on the front of the tv, on the far left I believe? That probably won't solve your issue since this has been an infamous problem for Mitsubishi.
If the reset button doesn't work the most probable fix are the (12) 1000uF capacitors (4 on each board) on the Power Supply, FMT board and the DM board. There are several other replies from reputable repair people on this site for this problem on the wd-xx525 series.
You probably just need to replace the DM capacitors. You can get the V26 DM repair kit from www.tvrepairworld.com which has the capacitors and the Cd with instructions
Jan 29, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green timer light. Won't reset, I know there is a master reset of the DM board, it happened after I replaced the bulb and I found a blog that suggested a reset using the front keys in a sequence.
actually your TV resets everytime you unplugg it and the green light should blink for 70 seconds, if it does not stop blinking there is a problem with either the power supply or any part of the signal circuit. on the 62525 model I have had great success replacing the capacitors on the power supply, they will look swollen on top, usually the (4) 1000mf at 35volts , the power supply is on the left side when facing the back , Mitts uses a lot of screws and plugs, but if you are good at taking things apart you can attempt is and save the $300-400 a servicer will charge.
gd lk
Thanks
Eric
Aug 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Jan 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Cannot turn tv on
mine required a bulb replacement it wasn't that old at the time
don't like being turned on and off a lot
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV won't come on
Menu and Input/Device button on front panel for 5 seconds, then this will flash a 2 digit seq. this will be your error code.
Apr 05, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
