Question about Biostar K8M800-M7A Motherboard
No detection of Western Digital (my passport) portable hard drive
For weeks i have been making reconfiguration with my bios just to be able for my usb to detect my protable hard drive. just recently i have found out the main problem, since i tried another pc, i only reconfigure the usb settings inorder for the mother board to give enough power that able the gadget to be detect.
my question is.... "How or where do i find this setting where i can give mor power to my usb inorder for my Portable hard drive be detected."
hope you can help me with my problem.
rgds.
Ronan Belleza
SOURCE:
CompuGuy44
  • 432 Answers
SOURCE: Windows did not detect SATA during installation
You need the manual to your motherboard to set it up in the BIOS. http://www.biostar-usa.com/docsmain.asp In the drop down menu select M7NCD ULTRA. I hope this helps. Let me know.
Posted on Jun 30, 2007
  • 6 Answers
SOURCE: SATA problem during windows install
You would need to make a floppy disk with the sata drivers on them for windows to use during the installation so it can recognise the drive... assuming you don't have memory problems that is...
Posted on Jul 03, 2007
ginko
  • 19396 Answers
SOURCE: Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Posted on Apr 03, 2008
  • 108 Answers
SOURCE: sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Posted on Jun 10, 2009
wenn428
  • 82 Answers
SOURCE: Intermittent failure to boot up does not detect
hi.. have some idea on that... when you try to format your computer.. pls make the SATA as "first boot" or "second boot" then try to boot again your computer.. thank you very much...
Posted on Jul 08, 2009
Recommend me branded USB drives ?
Honestly, any USB brand will cut it for you. What you want to ensure is that you are purchasing the proper version (1.0, 2.0, or 3.0) for whatever device the key will be associated with. Also make sure you don't buy too little or too much memory. But if you know all this and you just want a reliable brand, I would go with SanDisk.
Aug 04, 2015 | Computers & Internet
WD My Passport Essential USB 3.0 portable hard drive is not working on Windows Server 2003, please help me.
Try to flash the motherboard with the latest bios update ..... When it comes to the usb problem ...the motherboard needs to be updated......
Apr 06, 2011 | Western Digital My Passport Essential...
I am not able to detect my passport, while connecting to my laptop some body let me know how to detect it.
what is the suggestion that appeat at your laptop when you connect your hard drive?
is there the device not recognized device?if yes, it like your hard drive usb was error, change the usb cable and try reconnect again
Feb 19, 2011 | Western Digital My Passport Essential SE...
My western digital wd passport 250gb shows up as drive "d" but goes away
Make sure it is connected properly, normally when this happend it means the USB connection is loose.
Feb 15, 2011 | Western Digital WD Passport 250GB Portable...
Not detected in xp
hi
go to WD site and get drivers for XP downlod and run that then try hopw fully it will work
May 25, 2010 | Western Digital My Passport Essential...
My computer does not recognize my WD external drive
You've tried different USB cables; so, that cannot be the problem.
You've tried connecting to different computers; so, the problem is _not_ your computer.
What's left is "inside" the case:
* the USB-to-disk-drive adapter,
* the disk-drive.
Open the case, and remove the disk-drive, and connect it as a "slave" drive to some computer.
If it is detected, then the USB-to-disk-drive adapter that has failed.
If it not detected, then the disk-drive itself has failed.
FInd the serial-number on the Western Digital disk-drive, and enter it onto Western Digital's web-site, on the "check-warranty" page. If it's older than 3 years, the warranty probably has expired, unless you were "lucky" and got a 5-year warranty.
Western Digital has a "Customer Loyalty" program -- just buy a new Passport through their web-site, and cite the serial-number, and you'll get a significant discount on _their_ price (could be higher than your local retail computer-store) for a new (probably larger) Passport.
Apr 05, 2010 | Western Digital WD Passport 250GB Portable...
Where can you purchase a new casing for a Western Digital 120 Gb Passport portable hard drive?
If your portable Hard drive is in waranty then I suggest sending it back to them stating the problem.
Oct 20, 2009 | Western Digital Passport 320GB External...
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Biostar K8M800-M7A Motherboard Logo
97 people viewed this question
Top Biostar Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
