Bought a hard drive & each time I put the cumputor on it tells me I have an invalid disc & wont let me start up till I pull out the conection.
  • Computers & ... Master
  • 787 Answers
This is going to be a very general answer because I have almost no information to go on.
You computer is trying to boot off the new drive (it thinks it is C:) and cannot because it is a new drive.
If your drive are connected with a wide cable (about 1.5 inches) you have IDE drives. If your drives are jumpered as Cable Select and on the same cable, swap the physical locations of the drives. Otherwise make sure your old drive is jumpered as Master and the new one as Slave.
If they are on separate cables, the old drive should be connected to the primary controller and the new one to the secondary. Since you are having problems, swap them.
If the cable is a narrow one (about 0.5 inches), you have SATA drives and you need to go into the bios to change the boot sequence. Because I do not know the make and model of your computer I cannot be specific, try pressing the DEL key as soon as you turn on the power, this method is the most common.
I also predict that your next question after this works will be why windows does not see the drive. But, that is the next question. Right now see if this works, if not please post the make and model of the computer, the make and model of the drive and your operating system.
Posted on Oct 13, 2008
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
Aug 28, 2014 | Saws
Toshiba portege 2000 windows xp invalid system disk.
When booting, try going to the Boot Menu by pressing F12 when you see the Toshiba logo so you can select your hard drive as your boot device. After doing so, if you still get an "Invalid System Disc" error, then your hard drive may be shot.
Jan 04, 2014 | Toshiba Tecra 510CDT (P000224080)...
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Apple mac book pro wont boot it has cd stuck in side
Try starting with the button below the touchpad pressed, that should eject the cd, then try starting from a system disk, put the disc in and hold the "c" key and start. If it boots from cd then in your application folder choose utilities and in there find disk utility, select your hard drive and then select the repair disc feature, when that has run select repair permisions, if all is well choose start up disc from the utiliyies and select your hard drive (it should tell you what os version it has, if not you will have to run archive and instal and then run software update.
Oct 27, 2010 | Apple MacBook Pro Notebook
5 minutes playing online keep giving me error message that the disk is dirty. i know it's not i played the same cd to another xbox console it's fine. what should i do or what's the problem...
Hi chrisastig
try to save the game you are playing to the hard drive so as to play from hard drive & not from the disk ! this is assuming you have enuf room on ur hard drive to copy the game to ??
You will still need to put the game in (even when playing from hard drive) but i find if its a game you play a lot its well worth doing as it saves on the disc drive/disc spinning whilst playing :-)
saves on overall usage of the xbox too !
If its ok reading the disc for the first 5 mins of usage it should be ok to copy to the hard drive to play from.
If there is a fault with the disc itself it will tell you when you try to copy it to the hard drive & if this is the case (& its a game you like/play a lot??) then try to borrow a copy just to put on ur hard drive only & use ur damaged disc as the 'required even if playing from hard drive' notification to the xbox that you do own the original copy !
Damaged discs are usually ok for 'playing from hard drive' as the information the xbox requires is very little but enuf for it to allow you to play the game (from the hard drive)
You will find it a lot quieter whilst playing anyway ! i think so !
hope this helps :-)
please remember thumbs up :-)
p.s. refer to ur xbox user manual or drop me a mail if you have any problems doing any of the above ??
Feb 14, 2010 | Microsoft Xbox 360 Console
Disc Reading Error
my remote wont work recorder
Mar 24, 2009 | RCA DRC8300N DVD Recorder/VCR
Problems with Western Digital My Book 1000 GB Hard drive on Vista
download a free hard disc eraser program erase the disc space, you do not need wd`s software. then reformat the drive from vista choose ntfs format
Jan 23, 2009 | Western Digital My Book Essential Edition...
Computer shows invalid system disc,wont let me do anything else
This might be simple.
Assuming your son didn't make any internal changes to your computer. The problem may be that he changed your boot sequence to boot to floppy or CD instead of the Hard Drive.
Do the following:
As your computer is starting you will briefly have the option to hit F8 (I think F8 Might be another) for "start up menu or options".
This will take you to a screen of text where following the on screen text areas and moving the curser with the keyboard arrows and enter or escape check your boot sequence (the order of where your computer is to look for start up information)
It should read as follows:
#1 HDD1 (this text may vary)
#2 CDROM drive
#3 FLOPPY (if you have one) or other removable drive
If your son changed this and forgot to it back your computer may be trying to get start up information from a CD or Floppy instead of your hard drive.
Once you've changed this (assuming you needed to change it) following the instructions use the key to "save changes and exit"
Your computer should now boot up correctly.
Let me know if this helps
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
