Question about Sanyo DP32746 32 in. LCD Television
No signals found when searching for channels at setup
When I turn the TV on I get a blue screen that says:
"Please wait while your TV searches for channels" IT give a progress bar but status is always 0 channels found. When it is finished it says: "Please connect all signals and antenna to jacks and terminals on the back of the TV. Then press the channel up key." Which sends it back to the first screen I mentioned. It will not let you do anything and I mean anything else. I have tested the cable on another TV and it is working fine. I have tried unplugging the TV waiting and trying again but it did the same thing. Please help!
Cathy
  • 71 Answers
You need to press the channel up button 3 times if yo get message as please connect av sources. then do the manual channel search for 2 times. it should solve the problem.
Posted on Mar 05, 2009
No Signal
Reboot ur DirectTv box.By unplug,replug it and hour later to let the box upgrade it solfware.Go to ur tv menu setup rescan it again for all the channels.It should work now.
Mar 14, 2010 | Vizio VO47L 47 in. LCD TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
No signal and blue screen
hello
i think you might have a blue screen of death on your tv
--full str pka
Dec 31, 2008 | Polaroid FLM-3732 Television
No signal on TV2 with dishvip622.
If the blue light on the receiver is on then your tv is most likely on the wrong channel after checking cabeling i would do a reset on receiver first wait for it to come back on, then run a channel scan on your tv2 you can do this with orignal tv remote under the menu options. its also refered to as a auto search or auto program.
Nov 30, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Blue screen on all channels RCA TruFlat
This is NOT the problem. video games, dvd player and cable connection are all all a blue screen with sound
May 14, 2008 | Televison & Video
AKia pdp-4249g
I HAVE PROBLEM,THE SCREEN SAYS AUTO SELECT SEARCHING,THEN NO SIGNAL FOUND THEN THE TV TURNS OFF BY ITSELF
Apr 16, 2008 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Sep 11, 2007 | Sanyo DS20930 20" TV
No signal
Hopefully, anyway.
I had a similar problem, and my solution was this: I pressed menu on my TV and using my universal remote, went into setup, and then channel search (or near to that), at which point it began searching for analog and digital channels. This can take up to approx. 30 minutes. I suggest you occupy yourself while waiting; it is a sluggish process.
If you want assurance, your TV will have the majority of analog channels (basic cable), and a couple digital. I am basing this wholly on my experience, however. Once finished, it should switch immediately so a channel. Mine was a weather station.
I hope this is successful in helping you and those in the future.
Sep 02, 2007 | Televison & Video
Tv monitor turns blue during forward or reverse vcr search
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
Jun 23, 2007 | Panasonic PV-V4020 VHS VCR
Sanyo DP32746 32 in. LCD Television Logo
421 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
