Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Ws55805 convergence circuit
Ics convergence drive replaced . but 2resister was burned R8E03 & R8E00.
What are resisters?
THANK YOU
thupham_2002@yahoo.com
  • 171 Answers
Resistirs are designed to protect the circuits on the PCB. This is designed to allow a much cheaper part to burnout before the more expensive circuitry burns.
Posted on Oct 13, 2008
  • Todd Gale
    Todd Gale Oct 13, 2008
    Sorry, it is spelled resistors.
On the screen there is a green shadow on one side and a red shadow on the other side of every object in the scene
This tv has two big black ICs as convergence output on deflection circuit board that are defective and causing problem in tv, IC number is STK392-110
replace both ICs to solve tv problem, also chekc for faded color big resistor nearby these ICs or those got burn mark, replace these resistors with same value, aslo check cold/ dry solder joints in deflection circuit board and resolder these joint/ connections.
Thanks.
Jan 21, 2011 | Hitachi 65TWX20B 65" Rear Projection...
Television has double images like 3D, and bottom half of screen has a concaved image.
Please replace convergence ICs in tv, there are two big black ICs that has number STK392-110 mounted with big aluminum heat sink, replacement these ICs will solve your tv problem. Also check big resistor nearby these convergence ICs and replace if found burn mark or color faded.
On circuit board, IC location number is IC7001 and IC7002
Let me know if you have additional question.
Thanks.
Dec 25, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I am not able to use the blue and red convergence feature on my Akai Projection Television. Is there a solution to this problem? Thank you
Yes,convergence is dead ics and resister must be replace.U know how to solder right?Tries websites for convergence kit.Tv Repair World.com or Ebay.com.
Oct 05, 2009 | Akai PT5598HD 55" Rear Projection...
Two picters, round on top and round on bottom
You are right. Check the convergence ICs and resistors.i don't know the resistance values . But that seems to happen a lot with Projection TVs
Nov 28, 2008 | Televison & Video
Convergence
This is a problem with the convergence circuit. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. FIgure on $25 each for the ICs.
Dan
Jul 16, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HCL5515WX/XAA convergence Issue
I would replace both of the STK392-040, and check the resistors with one side out of circuit. The variable resistors are melted at the factory after the resistance is dialed in. I would check the resistance on it before replacing it. You can get replacement ICs and resistors at the following link and they provide free instalation instructions.
http://servicemanuals.vstore.ca/
Jun 09, 2008 | Samsung HCL5515W 55" Rear Projection...
Covergance problem.
Hello kidfarm,
Yes it is a good chance these two amplifiers are bad, since the convergence amps are usually connected as pairs.
red red green green blue blue
AMP1 AMP2
and I'll even venture to say that the resistors go to your green amplifier pair so in that case both AMPs (IC8D01 and IC8D02) should be changed out.
Mar 27, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Manual convergence -service mode
you have some resistors that are still open . If the ICs go a resistor or two usually go open and you cant always tell unless you remove 1 leg out of circuit and check that the resistance is within 5% of the rated resistance. Trying to adjust it by the service menu will only place extra strain on the new ICs and they will blow on you. The resistors are located right next to the ICs there are about 8 of them all I dentical. Very easy to spot.
Mar 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
Samsung TV model HCN5527W
The actual Convergence amp ICs not located on the convergence board are probaly what killed the origional convergence module, and likewise has killed the new board. You will need to change the convergence ICs first then replace the convergence module.
I would recommend getting the service manual . I can post a link if you would like.
Mar 17, 2008 | Televison & Video
PT-51HX40b BP819
Only use the same part number when replacing convergence amps, or you will need to replace all of the power resistors with recommended values for the convergence amps subsituted.
Dec 08, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
