Question about Sony Televison & Video
TV won't turn on
Hi...I turn on the tv, power light goes green.....after a few seconds, clicks then turns red........help
Sony 1080
    Scholar:
  • 98 Answers
Remove all the external connections connected to the tv.then un plug the tv wire from the power outlet.then after some time just plug only the tv wire back in the power outlet.do not connect the other devices and check if the tv is working as normal or not.if it does not works then
its the problem in the power supply board of your tv.
check for the fuse on the power supply board.
for any blown capacitors or ics.on the powersupply board.
also check for any loose soldering joints on the power supply board.
calling a tech is much advisable.if do not have proper technical knowledge.
it will not be too costly to get it repaired.
it is worth getting it repaired.as this is a common fault faced by many customers.
Posted on Oct 13, 2008
My sOny tv KF-42WE610.. Won't turn on.. I just
Please let me know how many times it will blink to determine where the exact fault came from.
Jdvillanueva
Jun 17, 2011 | Sony Televison & Video
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Sound went out, tv turned off, red light flashing...
The Lamp being bad as well as one of the three fans in the unit not turning could also cause the problem.
Hope this helps,
Skyassoc
Jul 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Mitsubishi medallion 1080 tv
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
Apr 27, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
110 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
