Question about Barco ULTRA REALITY - NETWORK INTERFACE MODULE Multimedia Projector
Barcovision 600 projector
I have this above projector, been using for a long time now and then. recently there is audio but there is no video signal coming out of it. when looked into the tubes from outside i can see the grid lines.
any help
thanks
natu
Ive recently bought a second hand Sony Cineza VPL-HS2 projector and it doesnt have an AVG input in the back. It does have a S-Video input, a 'video' input and a couple of audio inputs,
I think you mean "VGA" not "AVG". You can use the VGA to S-Video adapter to connect the laptop to the projector however you may get better results using a VGA to A/V (component) adapter to feed video into the RCA video input connector.
Nov 20, 2014 | Sony Cineza VPL HS2 Multimedia Projector
How do you connect projector to satellite receiver
Hi
A satellite receiver is no different to connect when it comes projector than a vcr, dvd player etc.
There will be Video out RCA plug normally yellow in color. There there are two chords for Audio. Normally Red for the right channel and white for the left. Both RCA. If your receiver is mono, you will have only one audio.
There are corresponding jacks in the projector. There might be a video out and audio out in the projector. You can ignore those.
If you use a amplifier, The connections will go from receiver to amp and from amp to projector. It is a good idea to have an amp in between. You don't have to send the audio to the projector (which normally is not great sound quality). Just use the home hifi for it.
So summary of ideal connection :
-Video out receiver in yellow RCA to video in projector.
- One or two Audio out (Red+White RCA) from receiver to your Hifi Audio in
Listen to Hifi and watch thru projector.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 24, 2010 | Epson PowerLite 3LCD Projector
Cannot conect presario V4000 to projector
Set your screen-resolution to 800-by-600 at 60 Hz.
Then, use Fn-F4, to see if the projector accepts 800-by-600 input.
Apr 10, 2010 | Compaq Presario Notebook
Sony Mp4 MP5 portable Multimedia Player Problem
hello.i hav a problem in my video player of mp4 but acctually audio player sound is absolutely right but video plyer sound is negligible.please tell me what i can do this.
Jun 08, 2009 | Universal Multimedia UNIVERSAL -...
Picture distortion
Hi!
That S-video cable...if it is longer than 1 meter you will get a poor picture. Get an component cable and connect your players thru that, that will improve thepicture 1000 times, belive me
This is the connectors back on your Acer
1 x RGB D-Sub 15pin
1 x Composite
1 x S-Video
1 x Component
And the component connector is way the best of them, its better that all of the together..if i may say so
Good luck
Nic
Mar 24, 2009 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Delay/ whitescreen when projecting video from laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
1.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems. YOURS sounds like 640x840.
3.
If you have audio in your presentation, connect a cable from your laptop's audio output jack to the audio input jack on the projector, and then test the volume by playing a file that contains sound.
4.
Start the Player on your laptop. If you want to only display the Player on the big screen, and not the desktop background, maximize the Player or set it to play your video using the entire screen (full-screen mode).
Jan 08, 2009 | Dell 3300MP Multimedia Projector
I recently bought a infocus in1 audio projector and i cannot get sound and picture together. only seperately by pressing the input botton
Sounds like you have the video and audio plugged into different inputs. For example the video is going to video 1 and the audio is going to the audio input of video 2
If you get only video one input and only audio on another input... Then the above described connection is the only thing that would cause this to happen!
Cheers
Jul 29, 2008 | InFocus Play Big IN76 Multimedia Projector
Need Drivers
Hi Jess
Is your PC's image splitt ?
Right click on your desktop and go to properties - then click on settings and then advanced settings.
You'll see a block with two screens on it. If only one is activated - activate the secondary screen as well.
If you are using a Notebook also try holding in the Fn ( Function ) button - just left of your spacebar and in your F-row buttons at the top there should be one with two screens on it - Differs from brand to brand of PC's.
Hope this helps you !
Mar 26, 2008 | ASK Proxima Proxima DP2000S Data Video...
Help
Hi there
You can easily check by looking at the PC Cable ( RGB or VGA ) and Video ( Composite) and the connection ports at the back. There should also be a description of each on the back of the Projector.
You can download the full user's manual for this Projector from www.projectorcentral.com , go to brands and choose InFocus and simply scroll down to your model.
Mar 25, 2008 | InFocus LP 600 Multimedia Projector
CABLE NEEDED
Based on your post/description:
TV - 4pins S-Video and RCA (yellow) Composite inputs;
Notebook - 7pins S-Video and VGA female.
There are several ways you can make it work:
1. Use a (7pins) S-Video to RCA cable;
2. Use a 7pins S-Video to 4pins S-Video adapter cable;
3. Use a VGA to RCA converter.
The links above are only examples of the commonly available. You may need to check with your local electronic/video store if they have similar products.
Should you like to tinker and DIY (do-it-yourself), this link shows how to make one.
Any of the above will work but video quality differs. Additionally, most if not all TVs can not accept high screen resolution of a monitor/LCD hence you need to lower your display to something like 800 X 600.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 13, 2007 | Computers & Internet
124 people viewed this question
Top Barco Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Barco Office Equipment and Supply Expert? Answer questions, earn points and help others
