Question about Acer Aspire 5315 Notebook
Cpu upgrade I have an acer aspire 5315-2326...can I upgrade the processor to 2.8 GHz or better?
    Genius:
  • 1,124 Answers
Your computer has one of these options:
cpu upgrade - spacer.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Posted on Oct 13, 2008
Want faster processor for acer x1300 it base unit
Here are the spec on your pc if the information you gave me is correct. You can only upgrade the cpu to the socket you have. I think you would be better off adding more RAM and a better video card that isn't onboard. Processor / Chipset
  • Type AMD Athlon X2 7450 / 2.4 GHz
  • Number of Cores Dual-Core
  • 64-bit Computing Yes
  • CPU Qty 1.0
  • Max CPU Qty 1.0
  • Chipset Type NVIDIA GeForce 8200
Aug 18, 2013 | Acer Aspire X1300 Dual Core 2.4ghz, 3gb...
I have acer aspire 4736z, can I upgrade the processor to 3.2 Ghz?
Please note that CPU upgrades in notebooks/laptops/netbooks are highly problematic because they depend on often uncertain motherboard specifications (different notebook models bearing the same series number in your question can have different internal and external specification and be based on different motherboards).
The most serious problem you face is that CPU upgrades in laptops/notebooks/netbooks inevitably require near complete disassembly and the correct reassembly of the computer. Inevitably, this type of work is best done by an experienced professional, trained for and capable of performing a warrantied repair. Understandably, the associated labor costs will be on the high side.
Also, upgrading the CPU requires the user to first risk expenditure on an item that cannot be returned to the seller or supplier if later found to be incompatible but could still be a potentially expensive replacement product, without being absolutely certain that is compatible with the motherboard for which it is intended.
So you will need to do extensive research on the specification of the precise motherboard of the precise model of your notebook. To do this, you will need the full, long, specific model number plus also the Serial Number (S/N) and Part Number (P/N) of the computer that are usually printed on a label underneath the computer. From these, you should obtain the P/N of the motherboard, then navigate to the support and product information pages of the motherboard manufacturer's website to verify the CPU compatibility specifications of the motherboard and then proceed from there.
Intel Pentium Mobile processor T4200 (1 MB L2 cache, 2 GHz, 800 MHz FSB, 35 W), or T3400 (1 MB L2 Cache, 2.16 GHz, 667 MHz FSB, 35 W), supporting Intel 64 architecture
Your notebook features the above Central Processing Unit (CPU) in its standard specification, according to Acer. This CPU is commonly referred to as a Dual Core / Intel Pentium M / 2.2GHz / 64 Bit Processor. This type and Model of Processor is outdated and the upgrade options available to you are limited.
The indications are that your best course of action would be to back up any important data stored on this notebook's Hard Disk Drive (HDD), restore the notebook to Factory Settings, sell it on eBay or CraigsList or any similar website popular, in your geographical location, for the buying and selling of Used Consumer Goods and then put any sale income raised towards a new, state-of-the-art notebook capable of performing the function(s) in which the current notebook is disappointing you and steering you towards radical thoughts such as CPU upgrades.
At the very least, consider several or all of the far easier, far cheaper and far less labor-intensive and labor-expensive upgrade options to improve the power, speed and performance of this notebook before contemplating a CPU Upgrade, such as, a Maximum Capacity RAM Upgrade, an Operating System (O/S) Upgrade, upgrading to a higher performance, higher Spin Speed and/or higher capacity HDD or newer technology Solid State Drive (SSD).
Your full notebook specification and CPU Upgrade Options can be found on the support pages of the official Acer and Intel websites below:
http://support.acer.com/acerpanam/notebook/2010/acer/aspire/aspire4736z/aspire4736zsp2.shtml
http://www.intel.com/en_uk/consumer/products/processors/compare-processors.htm?fam=corei5
Nov 21, 2011 | Acer Aspire 5315 Notebook
I have a acer 210t laptop with a 700 processor. can I upgrade to a faster processor and if so which one and how fast. Thank you.
Some laptops have "mobile" CPUs (physically smaller, and consuming less power) than the typical "desktop" CPUs.
So, if you know "how" to disassemble your computer, you may be able to remove the heat-sink & fans on top of the CPU, remove the CPU, and install a faster one.
However, if your current CPU is of the "Pentium III" series (which ranged from 500 Mhz to about 1400 Mhz), you may not be able to find a CPU that will be significantly faster than your current 1.26 Ghz CPU.
Instead, I would check the disk-drive -- if it is 4200 RPM or 5400 RPM, I would replace it with a 7200 RPM disk-drive, for better I/O speeds, and thus help your computer go "faster".
Also, I would add more RAM, again to make your computer go "faster".
Jun 09, 2010 | Acer Pentium III , 1.26 GHz Processor...
Celeron 540 upgrade
Aspire 4315 Specifications Specifications
Part Number
Varies by specifications
Processor / Speed
Intel Celeron mobile processor 530/540/550 (1 MB L2 cache, 1.73/1.86/2 GHz, 533 MHz FSB), supporting Intel 64 architecture
if you have a 2 Ghz processor installed, you will have to replace the motherboard to go with a faster CPU.. which will be spendy..
Hope this helps
May 06, 2009 | Acer Aspire 4315 Notebook
Prossor help
MS FlightSim is really tuff on the processor. You are better get a Quad Core Intel Processor, as no upgrade is possible for your Laptop. Also get a good graphic adapter, something like ATI Radeon 4850.
Mar 27, 2009 | Acer Aspire 5520-5156 Laptop
Can i upgrade the processor for my acer aspire 4520-5141?
Hi there
The computer can only support max 2.3 GHz x2 Turion CPU.
Thanks for using Fixya!!
Feb 12, 2009 | Acer Aspire 4520-5141 Notebook
Upgrading my laptop's processor from celeron 540 to 560
Fan cooler for Celeron is usually the same for 540 and 560 Ghz, there should be no need to replace cooling system if you pass from 540 and 560
Whenever you operates on CPU and cooling system you need to monitor CPU temperature using Bios or a dedicated software. Here is a good software to check CPU temperature and Fan activity: SpeedFan Download.
Regarding the RAM, some seller like this one (UK seller).sells Trascends 2 GB modules, seller says they work on 4315, you can eventually ask them if there is any issue with bios version and if you need to upgrade bios.
Remember, CPU upgrade on a laptop is not a simple operation, be careful if you do it yourself, as it is easy to damage the laptop when taking it apart. Regarding RAM, main risk is incompatibility, If you live in UK the seller above guarantee compatibility with Acer 4315, double check by sending them an email before buying.
Aug 11, 2008 | Acer Aspire 5100 Notebook
Processor
I told you my opinion, If I was in your shoes I won't upgrade the CPU.Professionals do not do works against Factory specifications, and I fixcomputers for living.
Acer says Pentium dual is not supported on Acer 4315, I can only tell you not to do such an upgrade.
Itwould be the same as if you ask me if you can mount a Jaguar engine ona Mini, yes, for sure there is the way to mount it, but the car won'twork as it is supposed to, and risk to blow at first corner.
If you really want to replace your CPU consider the following.
Acersays pentium 2 dual core is not supported on 4315, if you do ityourself you risk to damage the computer. Do not do the CPU upgrade ifthis is your only laptop, or if you care of this laptop, chance ofdamaging laptop are high. This kind of upgrades are done more as anexperiment.
I know Core 2 Duo T5300 1.73 Ghz had been installedsuccessfully on Aspire 4315, Acer says not to install any core duo, Iknow for sure Pentium duo T5200 1.6 Ghz works on Aspire 4315 with noneed for replacing cooling system.
Both chipset are difficult to find, best place to find them is Ebay.
Check this link for an extensive report on this matter:
check also: Is it worth upgrading the CPU on Acer Laptops?
Aug 10, 2008 | Acer Aspire 5100 Notebook
Re aspire 7104 being upgraded to duo core processor
No it cant be updated
Your acer aspire is based on the 910GML chipset
The Mobile Intel® 910GML Express chipset is optimized for the Intel® Celeron® M processor.
Here you can compare the 910gml chipset and 945 which is used by the core 2 duo.
http://compare.intel.com/pcc/showchart.aspx?mmID=22210,7419&familyID=7&culture=en-US
As you can see on the page there are key difrences between the chipsets other runs on ddr2, yours on ddr. the FSB support is 400 on yours and 533 / 667 on the 945.
also you can see the supported processor familys right there.
you can look for a
Intel® Celeron® M processor,
Intel® Celeron® M processor Ultra Low Voltage (ULV)
Upgrade cpu with maximum FSB of 400MHz
Apr 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Acer Aspire 5315 Notebook Logo
1,004 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
