Question about Dell Dimension 2400 PC Desktop
Dimension 2400 won't power on but for about 4 seconds
I push the power button in and both lights come on. It then starts to boot up and then shuts right off
  • kamper_1957 Oct 13, 2008
    My problem is somewhat simular i think. Mine seems to be stuck in standby mode. Only the amber light is on...i have disconnected all power to the unit and when powered back up goes right to standby....no green light at all, no power to monitor or keyboard either so no way to start up in safe mode. Any ideas on this problem?
  • Dell Master
  • 998 Answers
The problem kamper_1957 is having with Amber power light is not a standby issue but a low voltage issue in the computer. Replacing the power supply would be the easiest and cheaper item to try first. If that doesn't resolve it then the next suspect culprit would be the motherboard. I've also see broken USB port connecters short out the voltage and cause the power button to be Amber and not Green.
Posted on Oct 16, 2008
    Sergeant:
  • 352 Answers
At the beginning of the reboot cycle watch your screen for the option( F button)"Press F? to enter setup. You'll be in DOS mode. Look for or navigate to the "Boot/start Win. in safe mode." If this gets your OS up, go to system tools and start the "system recovery utility. Choose a date that takes you back when the unit was working properly and click restore, if all goes well the system will reboot in normal mode and things should be back to normal. We could talk about the issue being a virus or malware, but, will cross that bridge when we get there, try what I suggested first and see if you get results, its times like this I wish I could be there personally, alas, this will have to do for now.
anaanymous
Posted on Oct 13, 2008
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
The Whirlpool Dishwasher GU 2400 won't staart
Sometimes I have to push the cancel button on my Kitchenaid and start over and push the selection buttons again. and then push start. Don't know if this will help.
Jan 07, 2012 | Whirlpool Dishwashers
My dimension 2400 wont turn on it has a green light on the motherboard but wont boot up please help
What you can do is to try to open the casing and remove all the connections specifically the cables/connections from the power supply. Reconnect the cables and try it again. if still not, reconnect the memory modules and disconnect the connection/cable of the hard drive and give it a try. If that works, just do the same process and reconnect the cable back.
Note :
Ensure to unplug the computer first from the power before doing this. Once you have unplugged the computer from the power, press and hold the power button for 3-5 seconds. this will discharge all the remaining power that is stored on the capacitor.
Hope that works..
Happy TS...!
~jash
Sep 17, 2011 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400 with a blinking amber light what do i do
The blinking amber light on the dimesion 2400 generally means that the power supply on the system has gone bad. Switch off the system and disconnect the power cord from the back of the system . Press and hold down the power button in the front for 10 seconds.
Reconnect the cable back and try powering on the system.
If the same ,fails you would have to take the system in for repairs
Thanks for using Fixya
Proton
Sep 03, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
Dimension 2400 won't start up a green light comes on on the start button but nothing else? This isn't the first time this has happened, in the past what I could do was simply shut the machine off (hold the...
Hi There, the1st and quickest thing to try would be checking if the power supply is faulty, very common problem, if this isnt the problem then more than likly the motherboard. Let me know how you get on or if i can be of any help.
Regards
Grant
Nov 02, 2009 | Dell Dimension 2400 PC Desktop
DEMENSION 2400 WONT POWER UP
It sounds like the power supply went.
Take it to your local computer repair shop for repairs.
Good Luck.
Mar 13, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
117 people viewed this question
Alun Cox
