Question about Philips SACD1000 CD Player
How to remove the loader of Philips SACD1000
I need to open the tray of Philips SACD1000 manually in order to replace the loader.
the following the service manual of mechanical and dismantling instructions says:
Manually opening of tray
When it is not possible to open the tray with the open/close button, the tray can manually be opened. When no disc is loaded, unlock the tray by moving the slide from the left to right and pull tray outwards.
Remove 4 screws to remove loader.
My question: Please tell me where I can find the slide.
Regards,
Weishen
4 Suggested Answers
SOURCE: Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Posted on Jun 17, 2008
  • 567 Answers
SOURCE: Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Posted on May 07, 2010
dunnbiker
  • 8546 Answers
SOURCE: Hi. My Philips SACD1000 CD
Before you do surgery and regret it...
http://www.repairfaq.org/sam/cdfaq.htm
Posted on Feb 07, 2011
How to open Philips AZ1330D/37 CD tray manually?
There may be a small hole next to the tray. If there is one you can poke a paper clip end in there and the drawer will open. If there isn't one contact support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Jan 09, 2015 | Philips Audio Players & Recorders
Problem with the tray.it is not working properly and cant come out
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual
God bless you
Sep 27, 2012 | Philips DVP-3005 DVD Player
How do I remove the front of the tray on Marantz dv9500 so I can remove the transport from the enclosure?
Turn the laptop over, follow the guide lines of the DVD player, you should see one or two screws near the center back, remove the screw, take small needle or fine screwdriver and look for a small hole in front of the DVD loading tray, carefully insert in the hole until you hear a slight click, tray should pop open, pull all the way out and remove DVD driver. there is no need to remove bezel since everything comes out in one piece.
Mar 21, 2012 | Computers & Internet
Non si apre il cassetto e sul display compare la scritta "blocked"
Firstly if there is a dvd stuck inside the machine and it won't eject then try the following: Turn off the power at the plug socket and remove the plug then look on the underside of the machine. On some Philips dvd players there is a plain white label below where the dvd tray sits under this label is a slot which gains you access to the manual release. If there is a label and slot gently pierce the label using a small screwdriver and push the screwdriver gently in until it stops then move it from right to left. This action moves a lug sited under the drive unit, this lug is the manual release for the tray. You will then see the tray open and will be able to remove the disc, moving the lug back will close the tray.
But this problem on Philips dvd players and recorders is a fault with the dvd drive and is common on some Philips machines. The only way to cure it is to replace the dvd drive unit itself, the one positive is that Philips used their standard IDE or SATA internal dvd drives, the same as in desk top computers. However a replacement drive would have to be comparable to the exisisting unit to avoid further complications. Please take note as a safety warning this is a technical solution involving the opening of the machine exposing potentially live electrical parts and should only be under taken by a trained technician.
Hope this info helps, James
Apr 22, 2010 | Philips DVP3040 DVD Player
Tray wont open on my philips cdr600 recorder , can it be fix
You can try the following:
Unplug power cord.
Plug back power cord.
Press start and push repeatedly the eject button while the unit is starting, before the Player start reading the CD.
Try this a couple of times.
if that does not work, then you will need to disassemble the unit, unplugging from power, and removing the screws at the bottom and at the back, to access the drive and remove disk manually.
Jun 18, 2009 | Philips CDR600 CD Recorder
Drawer won't open. Says "blocked".
I had the same problem with a comparable device. It turned out that the drive belt that operates the ejection mechanism wears out or breaks.
To get at it you need to do the following:
1. remove device cover
2. remove the identification cover on the front of the DVD tray. This may be tricky if you can't open the tray. You need to find a way, because otherwise you can't remove the DVD unit, at least not on my unit.
3. remove the DVD unit by detaching the cables and removing four screws.
4. remove the two top screws on the DVD unit
5. remove the front top cover of the DVD unit by pushing the two tabs on the top of the unit, near the front.
6. Now remove the tray, by pulling it out as far as it goes and then pressing two tabs on either side of the tray. These tabs look like this:
7. Now you get at the drive belt. Originally it was black; I replaced it (temporarily) with a red one in the picture below:
8. Now put everything back together.
May 31, 2009 | Philips DVDR3450H DVD Recorder/HDD...
Rio HT2030 disc loader will not open
I have had the same problem. There is a rubber ban that acts as a drive belt to open and close the disc loader. i took the cover off and then the disc loader cover off to expose the bubber ban. Then i replaced it using two rubber bans from my daughter's braces and reassembled. Works great again.
Dec 23, 2008 | Rio HT2015 DVD Player / VCR Combo
SACD1000
Try resoldering the TZA1033 on the top side of the monoboard, and glue a piece of aluminium for cooling on top of it.
Jeroen Fortanier.
Dec 14, 2005 | Philips SACD1000 CD Player
Philips SACD1000 CD Player Logo
76 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
