My freestar tire rest light came on. checked and inflated tires to 44 psi as the tire said shoud be in them. the rest light is still on. how do I get it to turn off or reset?
Reset without message center:
To reset turn the ignition to the ON position, depress and Trip/odometer
button (located in the instrument cluster) until “TIRE RESET” or
“CHECK TIRE AND RESET” is displayed in the odometer display window.
Once “TIRE RESET” or “CHECK TIRE AND RESET” is displayed,
press and hold the button for three seconds. The low tire warning indicator light will flash three times
as the low tire warning system begins to initialize.
Reset with message center:
To reset turn the ignition to the ON position, press the set up button on
the message center until “SYSTEM CHECK” is displayed. Press the
RESET button until “HOLD RESET TO RELEARN” is displayed, continue to hold the button for three
seconds. The low tire warning indicator light will flash three times as the low tire warning system begins to initialize.
Tire reset light on 2004 ford freestar is on. How do you turn it off?
how to remove tire
