Question about Sony FWD-50PX1 50 in. HD-Ready Plasma Television
Sony KDF-50WE655 Was fine the picture went dim
My Sony KDF-60WE655 was working just fine the all of the sudden it went dim. It is still possible to view a program but not well. I have the manual and have adjusted the brightness but with little influence. Any ideas to fix this would be greatly appreciated.
  • Karlp327 Oct 13, 2008
    I lost my expert session.
  • 320 Answers
Replace the lamp.Use an original Sony lamp. Next would be the lamp power supply and last, the optical block
Posted on Oct 18, 2008
SONY WEGA KDF-50WE655 PICTURE IS DARK MY LAMP IS ONLY 2 MONTHS OLD
Where did you buy your lamp? sounds like its not a real philips or osram. Discount merchants sells some junk lamps. If you got it there, thats your problem
Jun 13, 2016 | Sony Grand WEGA KDF-50WE655 50" Rear...
We Have a Sony KDF-50WE655, we've replaced the lamp and housing and we still have no picture or sound. Can you help?
Make sure that lamp cover is fixed back on its position securely after lamp replacement, turn On tv to check.
If still no picture or sound then check power/standby light is blinking?
If yes, count it how many times it blinks after 3 seconds long pause and let me know to diagnose possible cause of problem.
Thanks.
Aug 01, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced the lamp and my tv still don't work
i have a sony kdf-50we655 tv and replaced the lamp. it still does not work green light blinks and then it powers down right away.
Feb 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Sony grand wega KDF-50we655. The picture was dim/dark etc. as suggested I replaced the lamp. Not much change. I did notice when the screen was White the left side had green in it and the otherside...
These tvs are LCD they have no tube to fill or color wheel.
You need to clean the glass light filters and lens.
If you remove the back and unplug the 9 plugs that go to the fans and LCD board/light housing it has 4 screws that hold it in to the front of the tv. 30 min Job.
Dec 12, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv brightness/vibrant
Most of the projection lamps are recommended to be replaced after 2 years. The older they get the more dim they will become. I would suggest replacing the lamp again. Some of the aftermarket lamps do not work as well as the factory replacement. I always spend the extra money and get one from Samsung.
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony wega kdf-50we655 went off and thier is a buzzing noise
Anything that sounds like electrical crackling will be coming from either the lamp or lamp driver/ballast boards or their interconnections. The lamp should be examined first as this is the most likely cause.
michtech
Feb 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Dim picture
Amalio, sony part number is A-1606-034-B generic part number is XL2100U I would buy it directly from a tv shop that works on sony tv`s that way your sure to get an original sony part, you can install it yourself instruction sheet comes in box with lamp along with allen wrench, good luck, video-tek
Feb 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF-50WE655 will not power up. Red blight blinks 4 times
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Jan 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Kdf-50we655 dim picture and turns off and then back on
Symptoms shows that Tv requires new Lamp.
Lamp replacement procedure is written in user manual. Let me know if you need further info about Lamp purchase or need user manual.
Please buy original Sony lamp for replacement.
Jan 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
try cleaning mirror and lens inside
Dec 16, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony FWD-50PX1 50 in. HD-Ready Plasma Television Logo
134 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
