Question about Ovens
F0 error code on GE wall oven
We used the powerman fix for the "dreaded F7 error". That problem was about 5 months ago. Now we keep getting an F0 error. In your F7 fix you stated that F0 is usually a shorted off key. What does this mean and what part has to be replaced?
  • 1 more comment
  • Anonymous Oct 30, 2008
    I too am having an F0 error code. I called the appliance store and he said it was either an E.C.R. (electronic range control) or that it was the keypad and he also stated that it would probly be about 300 buuucks to fix.
  • hacksaw14 Oct 31, 2008
    Our oven is displaying the same code, among a few more but the FO code is more often. We did the same thing; called the parts department, and they suggested replacing the control, but also explained that it could be the digital display and that it would cost an additional $200.00 (+) to replace it ourselves. My husband replaced the control and we immediately tried cleaning the top oven. It cleaned for about 2 hours, then started beeping the code and shut itself down. We had to shut the oven off at the breaker because it keeps beeping the code every 10 to 15 minutes. We don't know what to do.
  • Anonymous May 08, 2009
    F0 code and oven does not work.   What a piece of ****.  Last "plain" oven worked for 25 years.  This one is 2 years old and has a problem that costs as much as a "plain" oven costs, just to fix.
    GE never gain...
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Posted on Aug 11, 2009
  • Belfamily Nov 11, 2010
    THANK YOU! This worked and saved us hundreds right before the holidays when we use our oven most and have to stretch our dollars the furthest! We're so grateful to you for this tip!
I had a F0 showing up on my GE oven's display (model number - JTP15WA5WW). Reading postings on different forums, I opened up the display and disconnected the plastic strip cable and inserted it back in after a few minutes. That did not help so I thought the display (which costs about $220 in geappliances.com) was faulty. You cannot believe what I did to fix it!! I opened up the cable again and with my nails I kinda scratched the bare contacts that connect with the electric socket and that fixed it. There was some kind of debris coating the bare end of the terminals. My wife loves me more than ever before!!!!
Posted on Feb 22, 2011
It Worked! Thanks. I took a very fine piece of sandpaper and roughed up the end and put a piece of paper between the ribbon and metal where the ribbon enters the metal. Every thing is back to normal. Thanks to the post I saved 163.69 from Appliancepartspros.com
I hope my update helps someone else. My wife loves me even more now!
We are thankful!
Posted on Oct 07, 2012
  • Margaret
    Margaret Aug 29, 2014
    Hi, how did you all get the panel back on, we can't seem to fit it on with those screws and the slide in thingi.
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
GE Profile Performance Double Oven
I was getting only the F0 error code. The wiring diagram inside the stove said F0 indicated a bad off button on the keypanel. There were instructions to check the ribbon cable on certain lines, with values for the resistance. It seemed to check out, so I ordered a replacement and voila, it worked.
Jun 11, 2008 | GE Profile JTP56 Electric Double Oven
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
F7 error
Hi robpris,
My fix for the most common cause of the F7 problem can be found at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with over 1600 folks and most report success.
Please let me know if this works for you. Email me at:
hutchipop@yahoo.com
Regards,
Powerman
Mar 11, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
GE JSK05 Electric Oven
f-1 means the ERC which it the clock/oven control is bad. youll have to replaced the oven control to fix the problem
Nov 25, 2007 | GE JKS05 Electric Single Oven
Kenmore oven clock control installation instructions
Your prpblem is not the control, it is a short circuit in the ribbon cable between the keypad and control. You can find my fix at:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success.
hutchipop@yahoo.com
Nov 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
An F0 lights and beeps on the pannel for the bottom oven
F0 typically means a shorted OFF key. You can trouble shoot this with an ohmmeter. Turn off the power. Disconnect the ribbon cable. Check flat cable pins 13-14. Normally the ohmmeter should show an open circuit. Press the OFF key. The resistance should be 100 to150 ohms. If all this turns out to be normal, there is probably an intermittent short circuit. Try my fix at the following link:
I have share this with over 1360 folks and most report success.
Let me know at Hutchipop@yahoo.com
Nov 03, 2007 | GE Profile JTP56 Electric Double Oven
Error message...
The F7 is intended to indicate a stuck START key. However, a design defect may cause a false indication. This can be corrected by adding insulation to the ribbon cable. You can find detailed instructions at my web site. Follow this link:
All of the above must be entered as the address on the same line.
I have now shared my solution with over 1350 folks and most report success. It is simple and free. Please let me know if it works for you too. You can contact me hutchipop@yahoo.com
Nov 01, 2007 | GE JRS04 Electric Single Oven
Ovens Logo
6,211 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
