Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA big screen model# D52w20, Chassis# ITC222
Power light comes on for about 7 seconds then go's out.It doe's this 3x's and then stay's out. However, if I hold the power light button, it will flash once, and then blink 9x's quickly. TV never comes on. please email me at simsfrazierwater@yahoo.com1
  • 1 more comment
  • costz2001 Oct 14, 2008
    Power light comes on for about 7 seconds then go's out.It doe's this 3x's and then stay's out. However, if I hold the power light button, it will flash once, and then blink 9x's quickly. TV never comes on. please email me at costz2001@yahoo.com
  • lbej197 Oct 15, 2008
    I have the same problem. Help>
  • Anonymous Oct 18, 2008
    I have the same problem with mine. My TV is only 3 years old and this seems to be about the time it happens with everyone's.
We went looking for capacitors and found that everything looked ok. we plugged in the tv with no cable...totally works!!! It must be the cable
Posted on Oct 18, 2008
  • RCA Master
  • 5,138 Answers
Nine times out of 10 the problem is 3 capacitors cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v look at cp 150 if cap is bubbled up on top it is bad capacitors should be flat on top.
Posted on Oct 17, 2008
I just found an RCA D52W20 with the chassis ITC222 (not ITC222A) and I found there are the 3 bulging capacitors (I don't know their labels) and when I power on the TV the power light slowly blinks 3...
Ship the Board to PTS, They repair them 1-800-844-7871. The 3 Capacitors you are talking about are on he deflection Board CP150 2200uf 16v Cp114, Cp120, Both are 220uf 35v.
Sep 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My screen went blue and now the unit will onlyl power on for a few seconds and shut down
Very common problem with the ITC222 chassis RCA which is what your model is. The Blue CRT is most likely shorted. You can get a replacement CRT for your model at www.tvrepairworld.com and it also conatins the CD with instructions on how to remove and replace the CRT.
Dec 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 will not turn on.
I posted this earlier, however I believe it applies here too:
Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 won't come on
I believe this may be your problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you,
I hope this helps,
Shuttle83
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I hope this helps,
Shuttle83
52 inch rca big screen tv will not come on
Hello All,
This set has the ITC222 chassis which has a problem with bad capacitors CP240, and CP250. In any event check these capacitors to see if they are puffy if they are replace them and this should solve your problem.
I hope this helps,
Thank you,
Shuttle83
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't stay on
Hello mrscarpenter,
I hope this helps,
Shuttle83
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
167 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
