Question about Compaq Presario M2000 Notebook
Charger overheating and melting the tip, Irregular charging
Every time I put my laptop on charge the charger gets extremely hot and the nodule/tip that connects to the laptop is getting burnt. Also because of this I have to fiddle around with the nodule/tip to get it to charge. When it does start charging it will charge for a second then stop, then charge again and stop and so on.
Please help.
What am I to do.
Your assistance will be greatly appreciated
    Problem Solver:
  • 16 Answers
First, Check for damage (frays, tears, melting, or cracks in/on the insulation) on the power unit from tip to wall socket. If all looks well then I would check the voltage on the power unit by using a voltmeter. If it's within manufacturer printings on the box, then you might have a possible short.
Hope this helps.
Posted on Oct 15, 2008
Lenovo laptop's charging point getting hot
many thing made that happened, but the important thing is to check whether ur charger gives a 19V-21V or higher!, u can use a multimeter, or voltmeter.. if OK check if there is a space between the laptops connector nd its charging port . because the connector's metal can get hot if it's not connected as well...
GOOD LUCK
Feb 11, 2013 | Lenovo Computers & Internet
Asus charger won't charge
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Apr 06, 2017 | ASUS Original 19v 3.42a Ac Adapter Charger...
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Aug 04, 2009 | Compaq 389897-001 - HP/ Presario V2000...
Burning
The motherboard in your laptop is overheating badly if its melting chargers but more importantly its not charging at times as well. Both symptoms relate to a bad motherboard. Try getting it replaced if you can.
Aug 03, 2009 | Compaq Presario M2000 Notebook
Last time used,working good.BUT hot, tuned off normal. Next day wounld not Turn on,but charger light came on and charge batt.to full charge lite came on. TOOK FAN out in middle were heat tranfer white...
1. buy some transfer compound
2. replace the fan and heatsink over the compud do not spread compound with finger.
3. Reset the unit by takeing out the battery and unplugging it from AC source then after a few min. plug everything back in.
4. if that does not work you may have a overheated cpu and this would need to be repaired at this point seeing that the compd was melted off.
Jul 08, 2009 | Gateway MX7118 Notebook
Adapter going bad
get a computer fan from your local computer or electronics store
Dec 10, 2008 | Dell Inspiron B120 Notebook
HP Ze2000 laptop charger overheats
CHECK THE POWER OUTPUT RATING ON YOUR POWER SUPPLY AND SEE IF IT IS HIGHER THAN THE COMPUTERS POWER RATING, THIS INFO IS ON BOTH THE LABELS OF THE COMPUTER AND SUPPLY, IF ONE IS HIGHER THAN THE OTHER THAT WOULD EXPLAIN THE OVERHEAT, IF THAT IS NOT THE CASE, THEN GO TO ACERS TROUBLESHOOTERS WEBSITE OR CONTACT THEM DIRECTLY FOR HELP... JON T
Dec 07, 2008 | HP Pavilion ze2000 Notebook
Laptop charger gets very hot(50
Its absolutely a charger problem. This is not a big issue. If its charging perfectly then neglect it. or else replace it with new charger. Thank you...
Sep 12, 2008 | Computers & Internet
The socket where you plug the charger into the laptop is loose and now will not charge. where can i send it to be fixed and how much will it cost? I am in Niagara falls, ONtario
Hi
This is typically caused by tension on the plug. For instance, you allow the charger to dangle and hang on the plug. This causes poor contact and the socket gets hot and melts.
If you go to the manufacturers they will charge you for a new mainboard. Your best bet is to take it into a local TV/Hi-Fi repair shop and get a quote.
Aug 15, 2008 | Gateway Computers & Internet
Overheating presario 2100 charging port
hi,
 all laptops heat up rapidly if u place it on a flat surface...so when u place the laptop, keep a small support( like tv remote, ac remote, folded book) anythin like that, so that there is free ventilation of air beneath the laptop....dis might solve ur problem
good luck
trensetter
Jul 01, 2008 | Computers & Internet
Compaq Presario M2000 Notebook Logo
258 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
