Question about Sony KV-35V35 TV
PIP How do I change the PIP to a different channel?
  • 3 Answers
Easiest solution is to select chanel for your main viewing, then, no matter what the secondary chanel is, SWAP. Now you can select the chanel you want for the 'alternate' and swap away! Take note, the sound is also swappable (sic); you can watch one chanel while listening to the other. What you are viewing can be followed too with closed captioning. Neat trick for sports fans!!
Posted on Nov 22, 2008
When I activate the PIP on the remote, either one of the pic's are black or they are both the same. I am unable to watch a different cable channel. Please advise how to change channels on the PIP. ...
If your using a cable box it will not work, unless you get two boxes for that tv. You could get a cable splitter and have the cable box on one side and straight cable on the other side.
Mar 25, 2011 | Toshiba TP55F80/81 55" Rear Projection...
Black retangular box in the middle of the screen that will only go away temporarily when the volume is adjusted or the channel is changed
Is this the PIP option for your television? If so, there should be a PIP button on your remote. Try pressing that. It will likely move the box to a couple different positions on your television, but it should disappear after the repositioning. I hope that's all it is.
Jan 17, 2010 | Toshiba 27AF45 27" TV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
Pip
I know that on my Protron the pip does not work for different TV channels, only for vcr or dvd. I can get pip from those sources.
Mar 23, 2009 | Protron PLTV-32 Television
PIP change
you can change the channel of the small screen .just read the user manual of your tv.to your problem is only in the remote control
Oct 13, 2008 | Zenith Z32X31D 32" TV
How do you get to diffrent tv station to show at the same time (pip)
If your TV has built-in Duel Tuner then you can see 2nd picture in pip. In remote you have channel up-down button for main picture and another set of channel up-down for pip function to change channels in pip.
Sep 28, 2008 | Televison & Video
PIP
this tv does not have 2 tuners. So you will be unable to get 2 different channels on one screen. I have the same tv. The PIP is only good for watching a dvd/video and tv swapping only.
Apr 08, 2008 | Toshiba 50A60 50" Rear Projection...
Pip
how do i change channels with pip
Feb 29, 2008 | Televison & Video
Changing channels on pip feature
I THINK YOU HAVE TO TRY TO SOLVE THE PROBLEM WITH THE REMOTE CONTROLLER SHOULD BE  FIND A KEY FOR
USE PIP
Dec 06, 2007 | Televison & Video
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
