Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Emachine wont show on monitor
Have a emachine with xp it acts like its coming on but wont show any picture on the monitor tryed different monitors all the same result could the motherboard be bad
  • tim42220 Oct 13, 2008
    no beeps or anything it sounds like its loading up like it should but you cant see any kind of a picture or words on the monitor i think the videocard is all built in to the motherboard
  • David Eisenberg
    David Eisenberg May 11, 2010
    Either the motherboard, video card (if used) or the processor is suspect.
    Do you hear any beeps when you power up the computer?
    Master:
  • 538 Answers
Hmmm...you could try using F2 to access the setup..if that does not work..then that machine is truly unhappy..
Posted on Oct 13, 2008
  • A Womans Computer Man
    A Womans Computer Man Oct 13, 2008
    so ..there is no response...i suspect re seating the memory MAY get you closer
Wavy diag lines moving on monitor?
First, try a different monitor to eliminate that its just the monitor
If the other monitor comes on fine, that will show your monitor may need replacing.
You can also try the degauss button on your monitor screen (icon looks like a magnet)
Sep 01, 2013 | E-Machines eMachines Desktop PC
My desktop turns on but there is no sound or picture on the monitor and we tried a differant monitor
You have a bad motherboard unfortunately its time for another machine. I have seen this issue alot with emachines.
May 15, 2011 | E-Machines eMachines Desktop PC
Monitor not showing picture
This is not your Monitor Problem It is your System Unit Problem.
Some time Problem with VGA Card You Check your VGA Card . Hope problem will be solve.
Mar 11, 2010 | E-Machines eMachines Monitor E15T4
Monitor blue light comes on shows emachines logo and color bars then monitor turns off and light turns yellow
your monitor is beleiving it is not receiving any signal from your pc. 1 make sure your cables are secure. 2 make sure your pc is on. 3 borrow a monitor from a freind to see if your pc is sending the signal out, if the borrowewed monitor is showing a picture, hook yours back up. 4 if still not picture your mpcb or video pcb in the monitor is bad.
Oct 28, 2009 | E-Machines eMachines Monitor E15T4
Emachines t2899 will come on and fans run but screen is still blank
Actually, the monitor is fine. The problem is that the computer isn't booting. The power comes on and the fans spin, but the system board isn't starting. Try reseating the memory modules in their sockets and clearing the CMOS memory using the jumper on the system board. If the problem continues, try another power supply. Finally you may need to replace the system board.
May 13, 2009 | E-Machines T2899 PC Desktop
Computer start but wont Boot up.
Here are a couple steps you can do to verify something didn't come on correctly.
- Verify the monitor cable is connected tightly to the monitor and PC.
- Verify the power cable is plugged in.
If both of these check out is there a little LED light on your monitor that is on?
If not swap it out with another monitor and see if a different one works. If so we have a bad monitor.
If both do not work you may have a video card issue. Most EMachines come with a onboard video card which is bad news. If you have a onboard video card you will have to verify the warrantly though Emachine and get it fixed. Good luck and I hope things go well.
May 02, 2009 | eMachines W3623 PC Desktop
Emachine Monitor comes on a few minutes and cuts back off
I have the same problem and I think its the circuit board on the power on button and blue led. I unplug the board when the monitor is on and then the monitor stays on and works OK.
It don't make any sence it is only 3 parts switch led connector
anybody else run into the problem
Mar 29, 2009 | E-Machines eMachines Monitor E15T4
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
Still having trouble with EMachines T3882
I feel your pain. I finally moved my pc to a room with no windows! But seriously, try a different monitor first. See if you can borrow someone's to just try it before you do anything else. If that borrowed monitor works fine, then you know what the problem is. (Which I believe is the problem.) By the way, what started all of your problems?
Aug 20, 2008 | E-Machines eMachines Desktop PC
Monitor
Same thing is happening with my emchine as well. Mine is a T6412 series machine. I boought this machine a year and a half ago. Suddenly one morning the monitor started flickering. At first I thought may be some problem with the cables. I tried with different cables. Same problem. then I thought maybe my monitor has gone bad. So I went and bought a new Samsung monitor. Even with this new monitor the problem remained. So, I am assumng now that the problem is with my computer and not the monitor. Can someone please help. I do not usually come to this site. Can you please email me your solutions and help directly to amalandy@hotmail.com. Thank you so much for your help.
Jul 08, 2008 | E-Machines eMachines Monitor E15T4
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
71 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
