Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Sound fluctuates My TV has developed a sound problem.  The sound goes kind of wildly from really soft to really loud, and lots of static.  Sometimes it will be normal for a bit, but basically it's unlistenable.  Is this a big problem?  Is it worth getting fixed?  (I can't even lift the thing, and don't have a car...)
    Scholar:
  • 98 Answers
Yes its worth getting it fixed.as its the problem in your main boards capacitors they r gone faulty and needs to be replaced.
still before taking it to the repair center remove all the external devices from the tv and then un plug the main wire of the tv from the power outlet and then plug it again after 10 minutes and without connecting the external devices check whether the same sound problem occurs.if not the problem is due to the external device which you had connected.and if the same sound problem occurs then take it to the repair center.
Posted on Oct 13, 2008
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
Static crackling sounds
Replace the speakers or let it be repaired by some one.their may be rust near the speaker coils.just giv it a try.
Nov 20, 2013 | Yamaha Music
Sanyo DP26649 screen blacks out and sound becomes loud static
Most likely you will need to get a diagnoses performed on the set. Your problem could be with either the main board or power supply board. The million dollar question is do you repair or replace? With parts and labor to repair this set, you could come out cheaper replacing it.
Jan 15, 2013 | Sanyo DP26649 26 in. TV
Hitachi 53SDX01B sound
This set had lots of audio problems- some idiot decided to put the entire audio circuit on a single compact board---it develops all kinds of bad solder connections on the numerous flat Pak chips on both top and bottom of the board.
Board no longer available from Hitachi (srs board) and rebuild usually is over 150 plus shipping.
We send the board out for that as I have seen top notch experts spend hours trying to solder the board and not after have a working set.
Hitachi just crammed too many parts in too small an area and the heat bakes the board---Understand I was seeing this failure when these sets first came out--failing after a week or two in someones home.
Apr 13, 2012 | Hitachi 53SDX01B 53" Rear Projection...
I have a Vizio 47 inch LCD HDTV hooked to a Dish system. The volume fluctuates from very loud to very soft between ads and programs. It also goes from moderate volume to very soft within a program. Help!
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
Feb 18, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
Sometimes when changing channels the audio will become static and will stay static for 2-3 minutes then the TV will turn itself off and back on again restoring the sound..quite annoying
once electronic devices start to develop faults, they tend to be quite annoying. But once you can have it solved, then you are happy and feel relaxed once again.
The problem mainly is from the sound IC, it is having some problems, it might be experiencing some kind of partial contact therefore having a kind of break in its main function.
What you have to do is to replace the sound IC of the television and you will not experience the problem anymore.
TAKE CARE
Oct 10, 2010 | Philips Televison & Video
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Jul 09, 2009 | Televison & Video
Odd sound from Samsung DLP TV
Buzzing could be related to the lamp/ballast connection. Try removing and reinserting the lamp look for arching marks on the contacts that would suggest that the connection wasnt good.
Mar 29, 2008 | Televison & Video
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
