Question about Lowrance iWAY 350C GPS Receiver
Iway 350c GPS battery
How do you open the case and replace a dead battery on a Lowrance iway 350c gps?
  • 3 more comments
  • Anonymous Feb 20, 2009
    hi   did anybody determine if you can get the battery for this unit?  thanks  jon
  • examinern104 May 05, 2009
    I am also in need of a replacement battery for the IWAY 350c, does anyone know where to get one? I called the manufacturer and and they no longer supply parts for this model.
  • gerry boucher Jul 05, 2013
    i have looked high and low and all around . I really need help
  • Ernie Johnson Aug 09, 2013
    My unit comes on but the warning screen will not go off by using the touch screen on the x in the upper right hand corner does anyone know if this is a defective touch screen or is this battery related as well?
    My screen gets stuck at the warning notification and I am not able to use the upper right hand corner x to move forwardoes anyone know if this is the touch screen or is this battery related? I tried it plugged in and full power as well as in unplugged position
I don't know if this is the recommended way. Hold the unit facing you and look at the top of the unit. There is a seam about ¼” from the front. I simply used a small jewelers screwdriver and inserted it at the top of the unit about 1" from the side. I lifted the front section a little bit. It released one of six tabs that hold the face plate in place (two on top and two on each side). Repeat the same step on the other side then the sides. When you remove the face plate the silver on/off button will fall out, but don’t worry about that. Here is the tricky part. It has four star screws holding the back of the case to the electronics unit. I took a trip to the local Harbor Freight store and bought a star wrench set for $3.99. Remove the four screws and presto you can take the back casing right off. The batteries are at the bottom, but I can’t find any info on what type they are, so I don’t know what to replace them with, at least not yet.
Posted on Oct 17, 2008
Lowrance iway 250c wont charge?
The rechargeable battery is more than likely the problem and will need replaced, or the charging circuits are not functioning, "less likely"
Apr 10, 2011 | Lowrance iWAY 250C GPS Receiver
Iway 350 can't find its position>
This has plagued me for a while until I found the answer on Lowrance's website. Apparently, there are three rubindium crystals in the location sensor that go bad over time. Mine lasted three years. If you shake the unit for about 10 seconds, the liquid in the rubindium crystals activates and your position will be immediately found. Unfortunately, there is no user servicable access to change the crystals. Just shake it and it will continue to work and next time buy a Garmin or TomTom. They are much better.
Apr 05, 2010 | Lowrance iWAY 350C GPS Receiver
I won this GPS and it is telling me that it needs up dates how do I get the updates and do they cost
The updates it is referring to are the NAVTEQ database updates. This is the turn by turn street mapping and an update is available every year. You can purchase updates from the Lowrance accessories website http://www.lei-extras.com/store/search.asp?SearchType=Unit&Unit=iWAY+350C. The part number for this update is 95-63.
But you don't NEED this update. It costs $74.99 and may not even include updated street information for where you are. I would use it as is and if you think the street mapping is too behind, take the $74.99 and put it into a new Automotive GPS...you can get really good ones for under $100 now.
I do recommend installing the latest firmware update for the iWay 350 from http://www.lowrance.com/en/Products/Automotive/iWAY-350C/Downloads/iWAY-350C-Software-Update/.
Jul 08, 2009 | Lowrance iWAY 350C GPS Receiver
I try to use my Lowrance IWay 250c GPS and the
My IWay 250c takes quite a while to find itself and reset... sometimes several miles. I've learned to be patient. (At least you are outside, right?)
Rob
Jun 21, 2009 | TMI Products Lowrance iWAY 250C GPS...
Lowrance iway 500c no sound coming out of the speaker?any suggestions
Make sure that the volume wheel on the side of the speaker (built into the cig adapter) is turned up.
Make sure that the volume settings in the iWay 500 are up.
If that doesn't do it, then the speaker is probably bad. Replace the Cig Adapter power cable. If that doesn't do it, then the iWay 500 is bad (I think that would be a rare case).
Jun 05, 2009 | Lowrance Iway 500c GPS Receiver
Stopped working altogether
Unfortunately Lowrance is no longer repairing the iWay 500c model due to lack of parts. You may try calling them at (800) 324-1356 and ask if i's repairable. They may offer you an upgrade to the newer iWay 600c for a reasonable price. Well it's cheaper than a new iWay anyway...
Unfortunately there are no parts or repair manuals available outside Lowrance for any of their models.
May 20, 2009 | Lowrance Iway 500c GPS Receiver
Download for iway 350c
The sd card cannot be a new HD card, it must be the old standard version, There are 2 or 3 versions out there, you must fins one that is version 1
Jun 05, 2008 | Lowrance iWAY 350C GPS Receiver
Lowrance iWAY 350C GPS Receiver Logo
627 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
