Question about Dremel Variable - Speed Multipro Rotary Tool 395
Collet base removal
My 395 has the solid base of the collet stuck inside the threaded bit. I discovered this when I bought new collets to replace the broken one. How to I remove the piece? The new collets will not seat low enough to allow the cover to grab on.
  • high c kid Oct 13, 2008
    The suggestion got me onto the right track. After the threaded screw didn't work (it just wedged the collet against the sides tighter), I used a threaded tapper (right term?) and it bit into the soft metal quickly and was able to be "tapped" out with a small hammer on the tapping handle. Thanks!
  • cerickson Oct 27, 2008
    I am new with this product and I am very anxious to use it, My problem (s) are as follows: Can't get the collet into the shaft. Also when I attach the flex tube with the smaller tool I can turn on the regular one but I can't get the small one to turn also (almost done) when using the chuck how do you tighten it up to get the chuck to hold the attachment when using just the main Dremmel.
    I have no istructions or repair manuals (my husband can't find them) maybe that would help.
    A DVD that shows how to use and change accessories would be very helpful.
    Please send me instuctions on these issues or tell me where I can get the information. I down loaded a manual but it wasn't helpfull
    Thhank you in advance for your help.
    Connie Erickson
    (559) 679-0521 (cell)
    We have so many things we need to use this tool on and can"t use it.
  • 218 Answers
Try using a tapered wood screw or sheet metal screw as an extractor. Choose one of a size that will let its tip go down into the broken collet and get a grip when you twist it. If that fails, you might use a screw extraction tool.
Posted on Oct 13, 2008
Collet stuck in shaft.
On some models the collet stays put on purpose. You don't have to remove the nut either. But if you really do have to remove the collet and it is the type that is supposed to come out (maybe you need to use the 1/4 inch collet) then just stick a bit into it without the nut and give the bit a sideways whack with a piece of wood. If the collet has been pressed in tight by the nut without a bit in place, then you won't be able to fit a bit into it, and maybe the collet is ruined. Find the largest diameter shaft you can to fit into the hole and pop that sideways. Good luck.
Dec 28, 2012 | Bosch 1617EVS 2 Router
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
Sep 14, 2010 | Dremel 395 Variable Speed Multipro Rotary...
How do i take the bit off of a dremel multipro model395 type 5
unscrew the collet nut, and then if it's still stuck, tap the end of the bit on the table or something solid. It'll come loose then.
Mar 16, 2010 | Dremel Variable - Speed Multipro Rotary...
Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Dec 05, 2009 | Freud FT2000E 3 Router
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
My collet nut is stuck and I cannot remove it. Is there a trick to removing a stuck collet nut?
remove all the star head screws, unscrew the top plastic collet holding the plastic outer casing on. take a pair of vise grip locking pliers open the plastic casing just enough to expose the inner shaft inside the casing lock the vice grips onto the metal shaft between the bearing casing and the collet that is stuck enough to hold but not to dent it up. now that the vice grips are locked onto the main shaft get an adjustable wrench and size it to the collet screw size and turn it should come off rather easily or at least mine did just did it as i wrote this then screw the casing back together and happy dremeling hope this helps
Jun 27, 2009 | Dremel Variable - Speed Multipro Rotary...
How do you fit 6mm collet cone on new produce
You have, I presume, already locked the spindle and loosened the collet nut with the wrench, have you not?
Once the nut is loose, you should be able to remove it by spinning it off the threads by hand. Then insert the 6 mm collet cone into the collet,
carefully thread the collet nut back onto the collet, and tighten it with the bit in place.
Sometimes bits are a snug fit, especially into a new collet. If you have some fin sandpaper you can gently chamfer the very end of the bit where you first insert it into the collet, and this may help to insert it. If you have to, push a bit.
I have noticed that some companies tend to mill the shafts of their bits a little too close to the exact tolerance, or even oversize them slightly, and this can cause frustration when inserting their bits. In exceptional circumstances, I have resorted to polishing a couple of small bit shafts with very fine (600 grit or so) emory cloth, just to allow the bit to enter the collet. I would not recommend this with a new router collet, unless you have checked the bit with a micrometer and it is oversize. Odds are you just need to break things in a little.
The force need not be brutish, but you may need to use some force, yes.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Dec 29, 2008 | Makita 3612C Router
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
Changing a bit on my dremel
Depends on the head you have on the tool. If it takes collets, you need to match the collet size to the shaft on the bit. There are I believe 4 different collet sizes.
You have the threaded shaft which is hollow and connected to the tool. then you put the proper sized collet inside that shaft and half of it will stick out. This is what actually holds the bit. Next, you put the 'nut' on the shaft, but don't tighten it yet. Put the bit into the hole in the nut as far as it willl go, then back it out about 1/8 inch. Now you can tighten the nut by holding down the button on the front of the tool until the nut does't turn any more. You can buy a 'nut' that works with any bit, no collets used, for about $10. Home depot, Lowes etc or online.
If you're not sure what I'm talking about, you can probably find pics of collets etc. by going to google images.
It would probably pay to contact Dremel or look online for the manual also.
Jul 16, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
856 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
