Question about Dell Inspiron 6000 Notebook
Bios password reset
The motherboard password is lost
  • pisseur Oct 13, 2008
    Thank you , the CMOS battery did not solve the Bios pwd.Is there a jumper on the MBO that need to be rest ? the model of the computer is Dell Inspirion 6000.
  • Anonymous Mar 19, 2009
    I cannot get into the machine without the system or administrator password.Battery didn't solve the problem and I cannot find jumper on mobo
    Sergeant:
    Champion:
  • 334 Answers
Then u will need get take aprt labtop take battery out main batery out litte one also unplug it for 20 min then try thats can reset or jumpe ron mobo that resets it jump pins over ok
Posted on Oct 12, 2008
  • nick helpap
    nick helpap Oct 13, 2008
    yes ther may be jumper on mobo liek a reg pc get in ther look or cheak mobo speck sheet online
Skip bios password
Try this Method:
One of the most common methods to reset the BIOS password is to remove or discharge the battery on the computer's motherboard. If the power to the battery is lost or drained, the BIOS configuration will be reset to the factory state with no password. System settings made to the BIOS will also be lost.
Step 1 - Turn off the computer and ensure it has no external power (ie unplug the power cable. If it has a battery, remove it).
Step 2 - Open the computer's case or box.
Step 3 - Locate the computer's motherboard and look for the white silver button battery on the motherboard.
Step 4 - If the battery is not soldered to the motherboard, remove it carefully and wait for approximately 30 seconds.
Step 5 - Put the computer case back together and boot the computer.
Step 6 - If the "CMOS Checksum Error-Defaults Loaded" error message is displayed, the BIOS password has been reset.
In the event the CMOS battery is soldered to the computer's motherboard, you will want to seek a different method to reset the BIOS password on the computer.
Jan 06, 2014 | Computers & Internet
How to reset BIOS on Gigabyte GA-H55M-UD2H. Here's my story. A long while ago, I set a password to my BIOS. But then almost 11 months later, trying to use it, I can't remember the password. Is...
check your motherboard manual fo CMOS reset jumper location on you motherboard, and follow the instructions on resetting to defaults. Keep in mind that any customisations implemented by you in bios will be lost, so you will need to do them again.
Hope that helps
Cheers from NZ
Jun 19, 2011 | Gigabyte Computers & Internet
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
Lenovo n500 forgot bios password
Hello, If you forgot your BIOS password,do not worry, you can reset your system back without requesting a BIOS password,Simply unscrew your laptop and get the motherboard of your laptop, locate the CMOS battery on the motherboard and remove for sometime for the battery to discharge say 4-10minutes,or better still if you can locate the jumpers for the BIOS and reset it,the BIOS password will be removed.It is the battery that keeps the BIOS chip alive by suppling it power,if power is not supplied to this chip,then the information on it will be lost. So, remove the battery for some minutes or reset your BIOS jumper on the motherboard WISH YOU THE BEST.
Nov 22, 2010 | Lenovo 3000 N500 Notebook
Got a dell studio 1735 lost bios password
The jumper should be right next to the CMOS battery. It is also completely possible that simply pulling the CMOS battery would reset the BIOS enough to get rid of the password.
Jul 20, 2010 | Dell STUDIO 1735 Motherboard - H274K
Forgot password for bios setting
For this issue if you need to fix it with your self you need to follow the instruction from me. First you need to open your unit. Locate where the CMOS battery located.
The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is.
If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
Oct 08, 2009 | MSI K8MM-V Motherboard
Bios is passworded lost the password to open bios is there any way I can clear password to open bios?
What you can do. On your motherboard, there is a small quarter sized battery. the battery (taken out) will sometimes reset BIOS. or you can jumper the 2 pins in your motherboard booklet.
If not, find your BIOS name and version. such as Phoenix, and theres a couple more. try too google for: (My Bios) backdoor entry, Should help.
Aug 23, 2009 | LG Computers & Internet
How do I reset my lost bios password for Dell Precision M70
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
May 18, 2009 | Dell Precision M70 Notebook
BIOS password lost
Here is a link to the User Guide:
CUSL2-M User Guide
Save a copy to your HDD.
The procedure for resetting the password is on page 57.
Nov 12, 2008 | ASUS Intel 815E Chipset CUSL2-M...
Bios
If you have lost your bios password, only way out of this is accessing the motherboard and resetting the cmos.
If you access the mothernboard you can reset the bios removing the little coin battery from motherboard for one minute.
There is also a 3 pins bridged contact, near to bios chip, if you move the contact on the other two pins it will do same as removing battery.
Aug 28, 2008 | Intel Motherboard
Dell Inspiron 6000 Notebook Logo
357 people viewed this question
Alun Cox
