Question about AT&T LG CU515 Cell Phone - Black
LG CU515 New phone. But I some how have a number already set when I press the 1 key to call voice mail. How do I clear this out or reset so I can set up my email?
Sorry to say, but you cannot clear this. It is built into the phone's settings. However, you may set a number to the numbers that range from 2-9
Posted on Dec 08, 2008
    Brigadier General:
  • 7,752 Answers
Master reset the phone or delete the number on your speed dial
Posted on Oct 14, 2008
How do I set up voice mail
How to record a voicemail
    1)Call your Voicemail access number, or press its corresponding shortcut key (usually the number "1").
    2)Press the key corresponding to "set your voicemail greeting" or "Set up your voicemail."
    3)Decide whether you want to use an automated greeting, which usually gives out your number and advises callers that you're not available.
    4)Follow the prompts to record and save your greeting.
How to Record Voicemail Message on LG Phones
Nov 20, 2015 | LG Cell Phones
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 01, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I set up my voice mail
On the LG500g the number 1 is programmed as your speed dial number to connect to voice mail. So, just press 1, then press call (center button on navigation key), and follow the prompts.
Oct 03, 2014 | LG 500g TracFone
How do I access the voice mail on my LG Neon 2 cell phone?
  • Press and hold the "1" key to call into your AT&T voice mail.
  • 2
    Enter the default passcode (your seven-digit telephone number--not including the area code) using your keypad.
  • 3
    Press "4" to access the "Personal Options" menu. Press "2" to enter the "Administrative" menu, and then press "1" to change your passcode. Enter the default passcode, and then enter your desired passcode. Listen to the playback for verification.
  • 4
    Wait until you are returned to the main menu. Press "4" for "Personal Options," and then press "3" to change your greeting.
  • 5
    Press "1" to change your "No Answer/Busy" greeting, or press "2" to change your "Extended Absence" greeting. Follow the voice prompts to record your personal greeting (this replaces the standard "answering machine" recording).
  • Read more: How Do I Set Up My LG Shine Voice Mail? ' eHow.com http://www.ehow.com/how_5984327_do-lg-shine-voice-mail_.html#ixzz15IGt4VZz
    Nov 14, 2010 | Cell Phones
    How do I set up voicemail? New phone, mailbox says it is full, how do I delete messages?
  • Access the main menu of your Samsung Go Phone. Hold the #1 key down until you are connected to the voice mail system. If for some reason pressing the #1 key doesn't connect you to voice mail then call customer service at 1-800-331-0500. You will be connected with an operator who can help you troubleshoot the voice mail problems on your Go Phone.
  • 2 Follow the voice prompts and select "Listen to Messages" from the list of options. Bear in mind that checking voice mail on a Samsung Go Phone will count against your prepaid minutes.
  • 3 Once you have finished you can select the "Delete Message" option from the voice prompt if you wish to clear your voice mail messages. If not, you can simply press "clear" or hang up the phone to leave the voice mail system.
  • Oct 04, 2010 | Samsung Hue (SCH-r500) Cellular Phone
    I'm trying to set up my voice mail and I am getting a message "mailbox locked". Is there a generic password I can enter that will work? Too, can you send me a step-by-step go-by to set up my mailbox?...
    If you recieve the message "mailbox locked" then the password was incorrectlyentered too many times.
    To reset your password press feature 983
    the screen should say log:
    enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
    the display should say mbox, AA, and othr above the three soft keys
    press the mbox soft key
    the screen should say add, del, and chng above the soft keys
    press the chng soft key
    enter in the mailbox number you wish to reset the password on
    press ok
    the screen should say reset and next above the soft keys
    press the reset soft key
    press the Rls key
    your password should be reset to 0000
    As far as setting up your Mailbox, press your open mailbox key or press feature 981.
    When prompted to enter your password enter the password of 0000.
    The voice mail will make you change and confirm your password at this point. your password can be between 4 and 8 digits but cannot start with a 0.
    after the password is changed the voice mail will make you record your name for the company directory. once the name recording is accepted, the mailbox will be at your main screen.
    To record a greeting for your mail box,
    "8"for admin
    "2" for greetings
    "1" for record
    "1" for primary greeting
    "'1" to record your greeting
    at the tone record your greeting
    "#" to end recording
    after you record press 1 to listen 2 to retry or # to accept
    press "rls" key when finished
    Dec 22, 2009 | NorStar M7310 Corded Phone
    Setting up voicemail on sch-u340 phone..cannot read buttons on manual to set up..
    Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
    http://www.samsung.com/us/consumer/mobile/mobile-phones/more-carriers/SCH-U340ZBAUSC/index.idx?pagetype=prd_detail&tab=support
    Setting Up Your Voice Mail from page 10 in your manual:
    Voice mail allows callers to leave voice messages, which can be retrieved any time.
    Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
    1. In idle mode, press and hold the key or dial your own mobile number
    to dial voice mail.
    2. Follow the prompts in the new user tutorial to setup your mail box.
    Listen to voice mail
    to dial voice mail. After connecting, you will hear your voice greeting.
    2. Interrupt your greeting by pressing .
    3. You are then prompted to enter your password.
    Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
    JimmyC
    Oct 16, 2009 | Samsung SCH-u340 Cellular Phone
    How to set up voice mail?
    press and hold the 1 key down until it accesses voice mail then follow the prompt
    Aug 24, 2009 | LG Shine CU720 Cellular Phone
    Lg cu 515 voicemail
    call the carrier that you are with, they can help you set your voicemail
    Jun 09, 2009 | LG Vu CU920 Cellular Phone
    Voice Mail
    delete the speed dial number from the list or just master reset the phone
    Oct 12, 2008 | AT&T LG CU515 Cell Phone - Black
    AT&T LG CU515 Cell Phone - Black Logo
    526 people viewed this question
    Top AT&T Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
