Cannot get new DVD recorder/video cassette recorder to work .Hooked up to t.v. with comcast on-demand box. help
  • 38 Answers
If u hook it up thru comcast i think u have the recorder on the wroung. or if u are using video inputs u need to make shure that u are using the video out source from your comcast and u are going to video input on your dvd and then u should be just find because if u have it hook up right thru the dvd u will get a picture thru the dvd from comcast i hope that helps u
Posted on Oct 12, 2008
Is my Magnavox 1T HDD rECORDER COMPABILE WITH cOMCAST cable Box ?
If your Comcast box has a composite output, you'll be able to record SD shows. Use RCA composite video and audio cables between the box and the recorder. You'll have to set the box to the channel you want to record and leave it on. Then set the HDD/DVD unit to record from video input (L1 rear, L2 front) for the appropriate length of time. The manual explains this. The manual is available from Funai who built the unit with the Magnavox name: http://funaiport.com/upload/MAGNAVOX/Manual/MDR537H_EN_OM.pdf . See pages 19 and 42. If your TV and/or cable box only have a limited number of video inputs/outputs, you may need to daisy chain the composite video cables from the cable box to the DVD/HDD unit's video in. Then connect another composite cable from the DVD/HDD video out to the TV.
This Magnavox unit can only read analog (NTSC) cable video signals without a set top box. You will not be able to record a show and then watch another with the cable box.
I hope this helps.
(I know that my cable system's box has a composite video out. So it does work with most of the Comcast boxes. Many of the manuals are available here: http://customer.comcast.com/help-and-support/cable-tv/cable-box-user-manuals/ )
Sep 25, 2014 | Televison & Video
This dvd recorder worked PERFECTLY when I had digatal cable. As soon as I up graded to HD with a HD box from comcast, I cannot get the recorder to record anything. I hooked it up the same way as I did with...
The HD box from your cable company only sends High Definition Video signal which DVD does not support. Your DVD recorder "CANNOT RECORD THIS PICTURE" because it can not process (see) the High Definition (HD) Signal.
To record from an HD reviver you would need a HD recorder (Blu-ray) very expensive The standard practice for recording from a HD cable receiver id to use an DVR here is a link to one for about $100 some models will have a standard video output you could connect your dvd recorder to.
http://www.google.com/products/catalog?q=HD+Dvr&oe=utf-8&client=firefox-a&hl=en&cid=15241578777457062393&ei=puGPTNuoFIm4iwSJ2s1h&sa=title&ved=0CBcQ8wIwATgA#p
Sep 14, 2010 | Sony RDR-GX330
Will not record digital channels
first make sure the cable is running through you vcr then make sure you vcr is set to either channel 3 or one of the inputs
May 06, 2009 | Philips MWD2206 DVD Player/VCR
Local Comcast provider is switching to more digital programming
you will need the adapter and the good news is, the box is free, the downside to this is the panasonic recorder is going to need to only record on channel 3 or 4(there is a switch on the back of the comcast box) and the comcast box will need to be on the channel the program is on. I.E. Panasonic recording channel 3 or 4 from 10-11 am comcast box on channel 55 during that time.
Apr 21, 2009 | Panasonic DMRES15 DVD Recorder
What is the Code for a TOSHIBA DVD Video Recorder Mdl. #D-R550?
Here you go. Follow the link.
http://www.comcast.com/remotes/dvdcodes.html
I hope this solution is helpful. Please remember to rate this solution.
Feb 13, 2009 | Toshiba DR550 DVD Recorder
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
CAN'T RECORD ON DEMAND MOVIES
panasonic dvd recorder model dmr es 15 records Comcast on Demand programs. I use it. it's an older model so you probably have to get it on eBay.
May 28, 2008 | GoVideo R6640 DVD Recorder
Recording tv programs etc
I had same problem. With mine i could record wo the digital cable box but not with it hooked up. Would love to get some info about it.
Apr 27, 2008 | Sony SLV-D350P DVD Player/VCR
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
