Question about Pioneer DVR-233 DVD Recorder
Pioneer dvr 233-s recorder stops after 15 seconds when recording & wont record, but will still play disc.
I have a pioneer dvr-2333-s recorder. When I try to record it will only start to record for about 15 seconds then stops & doesn't record to the disk. Not only did I check the owners manual to make sure the dvd-r & dvd-rw's that I have been using are compatable with the recoder,but I have been using the same same brands for over 1 1/2 years with no problems. It also seems to have a problems initializing, & if you go into the menue & try to initialize the disk in video or vr mode it won't let you do either. When the problem first started I checked to make sure that the disc were clean & not scrated up, I even used a dvd lense cleaning disk to clean it with. This worked the first few times, but this no longer helps. I can't get it to record no matter what I try. However it has no problems at all playing any dvd's. I was wandering if something could possibly be wrong with the hard drive or if maybe it had some thing to do with it not reading the disk right.
3 Suggested Answers
PERS_Malta
  • 45 Answers
SOURCE: Pioneer dvr-225
no Sir there is nothing to do now because there will be no tracking of data apart from another pioneer dvr-225. Try inserting the disc in a similar dvd player! Please vote me solved Patrick
Posted on Jul 25, 2007
SOURCE: Cannot record DVD-R's
I could not record DVD-R's on my 633H.
Calling Pioneer I was told that I had to use DVD-R's rated no more than 4X.
I ordered 4X DVD blanks and have not had a problem since.
However, when I told the service man at the hi-end store where I bought the unit what Pioneer had said and that it fixed my problem, he said it was baloney and to bring it in and he'd have them fix it - that it should handle DVD's supporting higher write speeds.
I didn't take it in as the 4X blanks are cheaper and I don't want anyone mucking around in my machine when it is working OK..
Posted on Sep 08, 2008
  • 207 Answers
SOURCE: Pioneer DVR-233 DVD Recorder.
will any disc at all load if not u probably have something **** inside or broke inside do u have babies or little kids my 3 year old shoved part of a crayon in our dvd player and i had to take it apart and dig it out n cleanit and it still worked
Posted on Feb 24, 2010
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
Can't record on dvd+rw disc what kind of disc do I need Thank You
There might be a firmware upgrade to allow this I would use DVD-R for full compatibility however DVD+R media from Philips is increasing in compatibility with most NON Philips and Sony players.
Feb 25, 2010 | Pioneer DVR-225 DVD Recorder
Feb 24, 2010 | Pioneer DVR-233 DVD Recorder
Wont play my record dvd
Have you finalized disc after recording?
Aug 07, 2009 | Pioneer DVR-112D DVD RW Dual Layer Burner
How to record dvd in ordinary format?
I will presume it plays back fine on your dvd recorder.
In this case, you need to "finalize disc" for it to be playable on other dvd players.
Also, possibly, If you are using a dvd-ram disc, you must make sure that the dvd-player you are trying to use even supports dvd-ram. Most will NOT.
Also, Make sure you are not recording in VR mode. Only some very new dvd-players will support VR mode discs.
Jun 01, 2009 | Pioneer DVR-550HS HDD Recorder
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Himage 4010 dvr recorder
i have a propblem with the same dvd but mine when you play the disc the color is wrong it comes out red or green if you have the souloution to this problem plese contact me at chubb_pb4ugo@hotmail.com thank you.
Dec 05, 2007 | Aspire Digital AD-8091 DVD Recorder
Pioneer dvr-225
Jan 23, 2007 | Pioneer DVR-225 DVD Recorder
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Pioneer DVR-233 DVD Recorder Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
