Question about RCA RCR412C Remote Control
Remote Problem My RCA RCR412C AFTER PROGRAMMING IT TO MY DAWOO DVD PLAYER IT WILL TURN THE DVD ON AND OFF BUT SCENE SELECTION, PAUSE, START DOES NOT FUNCTION PROPERLY
I NEED MANUAL FOR MY TV
Posted on Oct 21, 2008
It's not working what can I do to program one for all controller to rca tv
HI,
The One For All 3 Device Universal Remote Control is preprogrammed at the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola cable box. To control devices other than the default brands, perform the following steps; otherwise skip this section:
HOW TO PROGRAM
1.Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc)
NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step.
( CHECK THE BELLOW ADDED LINK TO FIND THE CODE )
2.On the remote control, press a device key once (i.e., DVD/VCR, CBL/SAT, or TV).
NOTE: To program control of a VCR, PVR (or DVR), TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCRonce. After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions.
NOTE: To program control of a DVD Player, DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD/VCRonce. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SATonce.
3. Press and hold SET until the LED (red light) blinks twice, then release SET
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice.
NOTE: If the LEDdid not blink twice, repeat steps 2 through 4 and enter the same code again.
5.Aim the remote control at the device and press POWER once. The device should turn off.
If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For next code.
NOTE: If the device does not have a POWER key, press PLAY
6. Repeat steps 1 through 5 for each device you want to control. For future reference, write down each working device code following.
Electronics Equipment Repair Center ONE FOR ALL URC3021 UNIVERSAL REMOTE...
Jan 25, 2015 | RCA Televison & Video
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Code for tv daewo
try 10451, 10092, 10661, 10672
if none of these work, you can get more information on programming for your tv at
http://rcaaudiovideo.com/support/?kw=RCR412C
Jan 25, 2011 | RCA RCR412C Remote Control
No code search button
Turn on your TV, hold down tv or vcr/dvd depending on what you want to program. Then enter the codes this site gives you. http://remotefinder.rca.com/default.aspx?site=rca. Then release tv or vcr/dvd and see if your remote will change the channels.
Feb 18, 2009 | RCA RCR412C Remote Control
RCR412C input button.
what tv is it? might want to try another code if the button don't work with the code.
Jul 11, 2008 | RCA RCR412C Remote Control
Programming remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Apr 25, 2008 | RCA RCR412C Remote Control
Problems programming TVTECH universal remote controller
Jan 06, 2008 | RCA RCR412C Remote Control
RCA x-100 remote lost is this one all compatible?
PROGRAMMING DEVICE CONTROL
cable box.To control devices other than the default brands,perform the following
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
Combo, press CBL/SAT once.
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Dec 04, 2007 | One For All URC-3021 Remote Control
RCA RCR412C Remote Control Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
