Question about Sony Playstation 3 (PS3) Console
My PS 3 is having a hard time reading discs. Sometimes it will read them other times it wont or sometimes in the middle of a game i will get a blank screen
  • Anonymous Oct 13, 2008
    when i put in the games the lil loading circle just keeps going and nothing poips up
    I got the same problem on the same date as you.
Clean your games and when use your system keep it where form overheating.These problems will not happen if you read your owners manual.
Posted on Oct 13, 2008
    Scholar:
  • 44 Answers
Chances are, your disc drive stopped working. No big deal. Just call up sony (the number can be found in the back of basically any game's instrustion manual. You can also find it by pushing SELECT in the playstation store) and get it repaired. Mine only took about a week.
This is a common error unfortuately with PS3. Hopefully your system is under warranty and can be replaced for free.
Good luck to you and Happy Gaming!
Wont read game disc but will read dvds sometimes freezes up during game play
This is the 2nd most common problem with PS3's. This isn't a bad problem. Your laser/lens will need to be replaced. Do you see the time clock in the top right corner going around and around? If so, you are just having laser/lens problems. If you do not see the time icon spinning when you insert a disc, your PS3's Blu Ray drive controller board has gone bad and you will need to send it to Sony and not a
3rd party technician. Certain problems are only repairable by Sony. Good luck.
Jan 17, 2011 | Sony Playstation 3 (PS3) Console
My playstation has stop loading,but the disc continue spin
Hello, this problem is common. PS1 is a great machine, but the laser disc lens after serving us for years at one point it stops reading discs. Usually this problem doesn't happen suddenly, but there is a time period in between where sometimes it loads games and sometimes not. If you've noticed this symptom, then you may try to bring few more life to the PS. - Switch off your PS and open the round cover, locate where the laser lens is. Wet a cotton bud with one or two drops of a common glass cleaner. Clean very gently the lens for like ten seconds with circular movements, wait one minute so it'll get dry. Now put your game in and see if it has worked. You may try more than one disc if the first doesn't load, because some games are easier to load. - If this won't work, you may try to put your PS standing in vertical. Put it on one of its side, maybe better standing on a wall or on the side of the tv. It may sound weird, but sometimes it has worked for me. If one side wont work, just try also the other one. - If none of the above will work, i may suggest you to get a new one, on ebay you can find still many PS for few bucks.
Hope it'll help, good luck! Peter
Aug 03, 2010 | Sony Video Game Consoles & Games
I have one of the older model playstation 3 consoles, it plays ps2 games as well. lately it's been having a hard time reading the ps3 discs. sometimes I have to take the disc out and put back in about ten...
The PS3 disk and the Bluray disk require more intensity from the laser or, depending which model you own, has a seperate lens to read them all together. PS2 games are equivilant to DVDs and then you have CDs at the bottom. Check out "how to clean my Bluray lens" on google. Might even check youtube. All you need is alcohol and q-tips. Don't press down too hard when cleaning and don't worry, the alcohol dries very quickly. Clean it with alchol then cleans again with dry q-tip. very easy.
NOTE: when removing the Bluray drive from the board, the ribbon clips "flip up" and DO NOT "pull out" like most PCs (computers) do....if you are familiar.
Apr 26, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will not read my disc sometimes and other times it will read it but it will not work
The disc may be quote, "Corrugated", hence the laser is having a hard time following mis ~ aligned structural pattern. Try to use a CD ~ Lens Cleaner. :)
Apr 02, 2010 | Sony Playstation 3 (PS3) Console
PS 3 will recognize MW2 game but will not recognize any other game.. I will sometimes have to load disk a couple of times for it to work..
You may want to contact Sony- it's possible your Blu-Ray drive might be getting defective in that unit. That error, it turns out, means "can't start Blu-Ray game". It may be having trouble reading the disc. Have you tried any other games in it? The disk your loading might be defective.
Dec 17, 2009 | Sony Playstation 3 (PS3) Console
Our ps2 is very slow loading and sometimes it won't load at all. Other times is loads just fine.
It could be that the lens inside the playstation is dirty from dust. Try using a Cd cleaning disc that you can buy down at your local electronic store. If its not the lens then it could be the disc your playing. Check to make sure it doesnt contain dust or marks. If the disc contains scratches it could make it hard for the len to read the disc correctly.
Jul 28, 2009 | Sony PlayStation (PS) Console
Xbox wont read discs, unless i hit it....
open tray right??
-check the time and date settings,even the time zone as well
-try to load the disc without the hard drive or memory unit
-look for corrupted files at the memory, delete it
-do the system maintainance,
system settings>>memory>>hardrive, press y for device options, press this in sequence x, x, Lb, Rb, x,x>>yes
Jun 27, 2009 | Microsoft Xbox 360 Console
Ps3 wont read any game/dvd
ur disc reader is faulty/broke a quick way 2 get you back on games/ dvds go onto a demo or if you dont have download 1 via ps store and go onto it 1s ur on it press the ps button on your controller and the disc icon should be there now click onit and say yes 2 quit demo and ur sorted u will have 2 do this every time
May 31, 2009 | Sony Playstation 3 (PS3) Console
Ps 2 chipped
I have also envountered problems with dogs life, my only reasonable explination is:
dogs life is most propably written on a normal CD-R,
and sometimes a chipped PS2 struggles to read CD-R games, you will also find that older PSX games wont work either, hope this is of some help.
have a blessed day.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
Has trouble reading discs (intermitant) when burning
There are two common causes for these kinds of problems: software doesn't match, or media doesn't match. also, there a lack of info in here. is drive capable of reading dvd's when it is used for other purposes? 1. are you sure you got the right firmware? check for updates on brand site or on google. 2. try using several types of media from diffrent brands. some drives cannot read specific media (for instance, sony drivers sometimes having trouble with JVC media). 3. the least common, but worst option by far is a hardware problem. if drive is bad, you should try and replace it in case your warrenty didnt expire.
Mar 21, 2006 | Lite On SOHW - 1633S (show1633sbk)...
Sony Playstation 3 (PS3) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
