Question about Philips Televison & Video
I have a philips LX 200D dvd video digital surround system about 4 years old dvd player plays dvd's sometimes - pauses and restarts the dvd or stops - play dvd in another player dvd plays ok with no stop start. have tried cleaning the dvd player with a disc cleaner and have cleaned the dvd with a cleaner. thanks tony
Cost you $500 for a consoltaion
please pay quickly - inflation on the way up
thanks
tony
Posted on Oct 13, 2008
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
The LX 3750 dvd surround sound. Is the audio
It has a coaxial digital input. For whatever reason, they did not provide on optical one. This is not uncommon.
Jan 31, 2010 | Philips LX3700D System
Makes a buzzing/humming sound when playing a dvd or cd
that is a problem with the amp.
does this player have a dvd player built in or not
May 11, 2009 | Televison & Video
I have an old Zenith Digital Surround System the Receivver is a Model Z763B with a DVD Player/Recorder connected. When I play a DVD or VHS the sound can be heard through the TV and the Sound System,...
I have the same A/V receiver and in my setup there is an audio output (red and white able) coming from DVD player directly into Zenith Z763B. The video from DVD Player goes to TV input (yellow cable).
There might be alternatives to the setup mentioned above but I like to watch movie in a surround sound, rather than output from TV.
Jan 07, 2009 | Audio Players & Recorders
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Lx 9000r wont play any dvds even previously played
You can try reseting the unit.
Reset the set to the default factory settings:
All the information stored
(programmes, time and date) will be lost.
1.
Disconnect the set from power supply.
2. Press and hold down "STANDBY•ON" on the set and reconnect the set.
3. As soon as "IS TV ON?" is displayed, release "STANDBY•ON."
Hopefully reseting it will clear whatever problem it is having and allow you to once again use your DVD player.
Hope this helps. Good Luck.
Jan 22, 2008 | Philips LX9000R System
Kenwood DVR - 7000
Hi, same thing happened to my one of the above. I bought a cheap dvd player to view movies and run the audio through the kenwood to use the surround speakers.
Feb 21, 2007 | Kenwood DVR-505 DVD Player
LX3000D DVD Digital Surround System
the dvd player has a strip that comes from the lens to the board have that checked out by a yech probably it is broken or needs to be cleaned.
Mar 07, 2007 | Philips LX3000D System
Televison & Video Logo
150 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
