Question about Pioneer DEH-1600 CD Player
No sound deh 16
Everything worked fine and then no sound all wirers are connected fuses are good every thing turns on. PLEASE HELP!
  • Anonymous Nov 10, 2008
    no sound coming from deh 16 got lights just no sound
  • 624 Answers
The most likely reason for this is normally the output amplifier IC in the radio. If this is the problem, you would need to have the IC replaced. One bad speaker can also cause all the speakers to stop working.
If you have a multimeter to check the voltages on the speaker wires I could giude you thru troubleshooting it. It is very common for the amplifier IC to go bad in these radios. I work at an authorized Pioneer repair center and have fixed countless numbers of these radios. But before anybody can be certain of the cause of your problem, some thngs must be checked using a multimeter. Let me know if you have one, I will then tell you how to check what needs to be checked.
A repair for this type of problem on this radio will normally be too expensive to make it worth fixing. These radios normally cost about $100 brand new in the U.S. and a repair for this problem at a service center would be very close to that same amount, making it a better idea to buy a new one. If you do the repair yourself, it would only cost about $30 for the part. But you would need to know how to solder very good and be able to remove the bad IC and solder the new one into the radio. If you are not able to do this very well, please consider replacing the radio with a new one. You would first need to determain if the radio is at fault by checking the voltages on the speaker wires. They should all be around 6.5 to 7.0 volts. That is the normal voltage for speaker wires for these type of radios.
Let me know if you require more help.
Posted on Oct 13, 2008
My polo 2012 model 1.6. park lights not working ,brakes are working .when switch on park light there is a tick tick sound by fuse box . all fine.
Everything is not fine for the fuse to make a sound it has to be under a load even if the fuse never blow
Unplug the computer and check for a warm or hot
Wirer all over the car some where Thiers a wire grounding out
Apr 21, 2017 | Cars & Trucks
1985 Chrysler 5th ave 5.2l c.i.d. will not charge, new alternator,regulator, new gel battery new cables. if i charge the battery the car starts and runs great,but over the course of 6 hours or so if i...
it sounds like you did every thing write... well i would start checking for a burnt (fuse-able link wire)
i know chrysler uses alot of fuse-able links.. start at the positive side of battery...
i don't know if you know what this is? a fuse-able-link is a plain looking wire that will melt inside the rubber casing, the way i check them is by grabing the wire with two hands and try to pull the wirer apart.. if it streches it blowen....Hope this help you out???
May 22, 2011 | Chrysler Fifth Avenue Cars & Trucks
No Dash lights, or tail lights. All fuses and bulbs are good. Headlights and turn signals fine. Very confused....please help.
Sounds as if you may have a short did you check the bulbs? I would check the bulbs and make sure they are good. when you lift the rear hatch lid search around the wires and see if you have a exposed wire or perhaps a loose wire connection. Allot of times wires in a vehicle that year start getting frayed and worn from putting different items in the rear of the vehicle.
Dec 27, 2010 | 1994 Chevrolet Suburban
bad connection right at the blower motor. put the blower motor on and wiggle the two wirer connector. this is the most likely cause and the fix is to bend the prongs to get a tight fit again in the connector.
Dec 26, 2009 | 1994 Oldsmobile Silhouette
No break lights, tail lights or blinker on passenger side
check fuses with a tester. just because they look good can be missleading
Oct 05, 2009 | 1989 Jeep Cherokee
2002 mazda protege 5 will not start - will not turn over, starter is fine, battery is new, power is going to the starter, everything is clean, is in park or neutral, no clicking sound at all, fuses are...
Help please....I have Mazda Protege 2002...the car was driving good..and suddenly the car didn't start at all i changed the starter the battery is fine because when i start the car the lights comes on and the radio works. I don't know what is the problem is...when i start the car it makes noise of tik tik. Please help me????
Oct 05, 2009 | 2002 Mazda Protege
Freezer works fridge does not on a GE GSS22QGMC BB
you need to take freezer evaperator cover off , then turn it to defrost and test the supply voltage across the defrost element. if no volts then test the round disk looking thing with 2 wirers comming out of it . with the supply power removed from the power point, the coil frozen up , disconnect these wirers and use a continuity checker such as a multy meter on diode check or buzzer mode, you should have a closed circuit through the defrost termination thermostat (round disk with 2 wirers) , it is in series with the defrost element thus cutting the power to the element if the coil temp gets too high and terminates the element , the timer will time out after it's time duration is reached. A good way to test the motor in the timer is to put a texta mark on the dial of the timer and check it in 1/2 hr, to see if it has moved.AFTER YOU HAVE PUT THE ELECTRICAL CONNECTIONS BACK AFTER TESTING THE TERMINATIN THERMOSTAT AND MADE IT SAFE, YOU WOULD PLUG IT BACK IN.
The defrost timer needs to be connected to power of the fridge to opperate.
****. let me know your progress pls.
Mar 31, 2009 | GE Refrigerators
Kenwood hac 9152d, was working fine now doesnt output any sound
Check the fuse on the amp.
My girlfriend had the same thing, light was on, no sound whatsoever. The fuse on the amp had blown, but I'm guessing some current must have made it through to just put the light on. Make sure you have a 40 amp fuse in it, that's what it needs.
Good luck
Dec 10, 2008 | Kenwood KAC-9152D Car Audio Amplifier
No sound from hdmi cable
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
I have a pioneer 5.1 channel surround sound system and it powers up and everything seems to go fine but you go to turn it up and no sound comes out of the speakers already checked speaker wire connections...
Does the protection relay click 3 to 5 seconds after initial power on??? If not, your unit is staying in "protect" mode to save your speakers because the output transistors or output IC is shorted and sending 40 to 60 volts at your speakers. Not a good thing, but at least it saves your speakers.
Good Luck!
Oct 03, 2008 | Pioneer Audio Players & Recorders
Pioneer DEH-1600 CD Player Logo
154 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
