Hello, I get a mild electric shock from the strings on my bass guitar after i have turned my amp on. Nothing seems to be wrong with the bass itself and i have checked the plug for loose wires or split insulation & there's nothing wrong there. I have also done a rudiimentary check of the wiring inside the amp and as far as i can see there is nothing wrong there. I did change the extension lead that i was using for a new one & i have also changed the guitar leads to new ones as well but the problem persists. can anyone advise me further please?
  • 1,861 Answers
Robetek is spot on.
I worked in the live music biz for 27 years, as lead soundtech. I ALWAYS checked the instruments for possible voltage backfeeds, onstage, before the soundchecks. I have noticed more often than I can count that poor grounds, or earth, as Robo has stated, CAN AND WILL shock you. Or worse.
I have personally measured 70 volts DC between guitar strings and the microphone (in this case, a Shure SM-58; with a metal windscreen)...AND got shocked doing it...70 volts DC is enough to stop one's heart. Most always attributle to bad grounds, no grounds, or "reversing" the grounds to kill the "hum" found due to various electrical incompatibilty....
2 actual cases in point: The bassist for Uriah Heep, Gary Thain, and the lead guitarist for Stone the Crows, Les Harvey (he also played lead guitar on "All RIght Now", by Free)..., were BOTH electrocuted onstage, at a live gig. No way to die, my man, no way to die. and AVOIDABLE.
We experts hear at FIxYa are concerned about the health & well being of all of the "askers", like you, and we do NOT give out **** info.
PLEASE H\heed Robo's words wisely. Get your stuff all checked out. Everything. Guitar, amp, all of the cords, and anything else that you may come in contact with, anywhere.
The life you save may be yours. Not busting on you, my friend, just trying to help.
Posted on Oct 27, 2008
  • Toyota Ed Oct 29, 2008
    Thnaks for the FIxYa! Much appreciated. Could you please front Robotek a FixYa also? And,if you need ANY more help on your shock issue, PLEASE feel free to call on me, anytime Best regards, and THANK YOU for choosing FixYa.
  • 1,512 Answers
Hi FR101621
This is not good, you should not get electric shocks of any part of your gear. I strongly suggest that you take it to a qualified electronics guy that can perform an electrical safety check on it for you. It may be that the earth potential of your mains is different to the earth potential of the floor you are standing on. This may cause a small shock(would depend what country you are in and the mains system supply you are using). In any case, I would (for your safety) get it checked and tagged as safe. This is the only way to be sure you wont eventually GET KILLED!! Does not cost alot, usually about $30. Then you know it is good
regards
robotek
Posted on Oct 13, 2008
  • Graeme Ross
    Graeme Ross Oct 27, 2008
    I should clarify here that there is probably an leakage to earth issue with the amp. The basses strings should be at earth potential, so you should NEVER get a shock from them unless there is an earthing issue with the amp, the supply in your house, or the front end of the amp, or internal to the guitar. We have to set aside static discharge from this because you tell us the problem is only there when you have the amp turned on. If you do not have a hum issue when using it, then there is certainly a safety issue here. PLEASE GET IT CHECKED OUT. Let me know how you got on.
    regards
    robotek
My fender frontman 15r guitar amp has too much of a bass sound on e-a-d but too high on g-b-e I'm using a silvertone guitar with a 5 way switch how can I get goo clean sounds for country and blues?
As a guitar tech I suggest that you simply lower the pickup height on the low strings [by turning the height screws clockwise] then the low strings will blend better with the high strings.With a 5-way switch try the 2nd and 4th positions for a more out-of-phase twang too! Good Luck.
Sep 17, 2013 | Fender Frontman Amp 15R Guitar Combo Amp
Fret buzz only on E string. Adjusted truss and action, and still buzz. Some relief when I turn bass knob higher than the rest
This sounds like a worn nut groove. The string is sitting too low. Does the buzz happen all the way up the neck or just on open string?
Aug 14, 2013 | Dean Guitars Dean Edge E09M Electric Bass...
Hey my ax260 strings rattle alot mainly the bass strings? and every time i touch the coil tap knob a ugly sound comes from the amp its not even a year old yet and never been knocked over or droped could...
Strings "rattling" is usually guitar setup. This has to do with string height and POSSIBLY the neck truss rod. For the latter, have a guitar shop set it up for you. Hum from touching a knob is likely a broken ground wire in the cavity of the guitar. Also view videos on YouTube search "Guitar setup"
Apr 27, 2011 | ESP Ltd EX-50 Electric Guitar
When i play my bass through my amp it is really loud but when i go round my tutors for lessosns he has to turn his amp way up to get any sound at all.
His amp probably has lower gain. They vary quite a bit. Also the size of the speaker will affect it a bunch. If his is a tiny practice amp your bass will not generate much noise.
Mar 18, 2011 | Washburn Taurus T14 4-String Electric Bass...
This bass squels if you have a bass head and cabinet. i had a 100W amp and it played fine then upgraded to a head/cab. tryed playing it with loud volume, squels. anyway to fix this?
Turn down the treble gain and mid gain... you don't need it for a bass. Prevent the guitar from "hearing" the output of the amp directly. The guitar strings make a good microphone.
Feb 27, 2011 | Epiphone EBO Electric Bass Guitar...
Takamine eg523sc... the bass string (6th) is about 30% less in volume as the other strings what could i do to correct this problem?
You should take this to a guitar shop for setup. If you have correct strings on there the other thing is to check any EQ of whatever you run this into... If the amp can't handle the real low bass, it MAY appear to be a guitar problem but in fact is an inadequate frequency response at the low end in the amp and speaker.
ALSO some people believe it or not get deaf in the low range if they have damaged their ears when young. Procure a sound meter to VERIFY the sound intensity level... You may find the level is the same for the different strings.
The weak spot for bass is the SPEAKER in the amp.
Feb 14, 2011 | Takamine EG523SC Jumbo Acoustic Electric...
Bass strings are too loud in comparison to treble strings whe played through the amp
Adjust this using the EQ on the amp and to a lesser extent the tone controls on the guitar.
Often people boost the bass way up causing this problem.
Feb 12, 2011 | Epiphone Sheraton II Guitar Electric...
My new SWR workingpro 12 has a low frequency permanent noise, any idee ? Maybe from the Power supply... Thanks, bolliger_rudolf@bluewin.ch
All amps make a small amount of noise (system hiss) but the amps own power supply should not cause a problem on it's own.
However if the frequency is around 50hz (the G 2 1/2 octaves below middle C on a piano) it is most likely due mains electricity interference or an earth (grounding) issue.
Here are a few things to try to identify the source.
  1. Could be a lack of earth (grounding) This is potentially VERY DANGEROUS and could result in electric shock if you touch a metal part of the amp or touch some other metal object (like a microphone stand at the same time as your guitar strings). Check the earth wire is firmly attached at both ends of the power supply lead.
  2. Could be a defective mains socket - try plugging it in to a different one, preferably on a totally separate circuit.
  3. Could be an earth loop. These can occur if you are using the amp with an output to a public address system or mixer that is also earthed because of a 'potential difference' between the two earths. Solution - use the balanced (xlr) output which incorporates an earth lift rather than the unbalanced jack output.
  4. Unplug any effects pedals, foot-switch etcetera to see if that eliminates the problem. Turn off any internal effects, including bass intensifier.
  5. Make sure any signal cables (guitar leads) have good quality screening and that the screen is well soldered to the jack plugs at both ends.
  6. Ensure signal leads do not lay along side (parallel) close to mains electricity cables but are well separated and only cross at right angles.
  7. Move the amp away form other electrical equipment that may have a powerful magnetic field (especially CD or DVD players, hearing loop amplifiers, radio microphone transmitters / receivers, mobile phones
  8. Turn around or stand in a different position - it might simply be the pick-ups in your guitar causing interference in the magnetic field of the power supply.
  9. Does plugging in or unplugging a signal lead / guitar make any difference? This particular amp requires only mono jack plugs a stereo (trs) plug may be shorting across terminals
  10. Does it change when you touch the strings with your hand? If yes check internal wiring and screening within the guitar.
Feb 09, 2011 | SWR Workingpro 12 200watt 1x12" Bass Combo...
When playing my electric guitar, i get shocks through the strings. What could be causing this?
hello, this could easily be caused by something your wearing or any fabric thats near the strings.anything that could cause static.if not there could be something really wrong with your guitar!!!!
Jan 30, 2011 | Audio Players & Recorders
77 people viewed this question
 Grubhead
Grubhead
