Question about Lite On Computers & Internet
I have a Lite-On LH20A1P dvd drive. The problem is, it starts to write and the about a minute later it kicks out the disk saying - could not perform end of Disc-at-once. Then burn process failed. Could this be a driver problem? Or something turned off that should be on?
  • velut_umbra May 11, 2010
    Are you overburning the discs? Not all drives handle well that feature.
  • 49 Answers
-There a lot of things we may consider.I'll give some few things.
-It may be your dvd drive is not working properly.
-It maybe the setting of your dvd drive is not configure properly.
-It maybe the blank disc is having the issue not the dvd drive.
follow this steps to check and troubleshot:
-Set the dvd region
right click on my computer select properties, go to device manager click the + sign under dvd drive, right click on you dvd drive-choose dvd region.
-Enabling CD recording
Click on My Computer-right click on dvd cdrom drive-go to properties-select recording, then check if the Enable CD recording has a check on its box, then check the box that says Automatically eject the CD after writing.
If this steps will not work then send me feedback so we can move on to the next level of troubleshooting.
Posted on Oct 14, 2008
What is the difference between burn a cd and formatting a cd
Formatting a cd is to make it ready to add files to. Burning is actually adding the files to a cd. You can only format re-writables though.
If you make a multisession cd using a normal cdr then the first time you write to it the disk is made to accept your files for that session but also accept files at a later date, as it leaves the disk open and does not finalize it.
Nov 30, 2011 | Lite On Lite-On 52x32x52 CDRW & 16x...
Of late I am seeing that the LiteOn LH20A1P that I have on my computer is very slow in reading as well as writing. It goes only upto 8x while reading. I am using SONY 20x DVD discs. Is there any way to...
Thats a very unusual problem. I have had this drive in the past and apart from being noisy as all lite-on's seem to be it has given great service. the only suggestion i can make is that you update the firmware by going onto Lite on's site and download the latest revision of firmware. if still the same then can only assume the drive or your burning software is corrupt.
Aug 07, 2011 | Lite On LiteOn LH-20A1P - Disk drive -...
When a disk is in the cd/dvd player a message says there is no disk. Will not play music or burn a disk.
this is likely to be a problem with the drive. perhaps the lens needs to cleaned. use recommended drive lens cleanner, reboot system and ty again. if the same reinsatll your os
Sep 23, 2009 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Unclean disk / frezzing
The laser is starting to go bad in your dvd drive. You can either replace the laser if you know how to open up the dvd drive, or just replace the whole drive. You can get them off of Ebay.
Aug 21, 2009 | Microsoft Xbox 360 Console
Lite On LH-20A1H DVD RW burner refuses to recognize DL disks?
I have an LH-20A1S, & I am using Roxio Easy CD
Creator 6; Yes, I know there are newer versions, but they all ****! Anyway, it USED to work just fine in recognizing DL DVD's W/the updates from Roxio's site. & now there is no option there for this size (8.5)w/in the actual Creator prog. Is it the drive? This JUST started happening recently. Any clue if it IS the drive? & if so, any idea what caused this? I've always used Lite-On's & have NEVER had this sort of prob before! & of course it is out of warranty, & a discontinued model to boot! standar DVD drives are real cheap inprice these days, but STILL I do't wanna have to buy an new one if I can 'fix' it. BTW, I have updated the latest firmware for this drive from Lite-On's site too, & it didn't resolve this issue either!
__ERIC
Jan 31, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
LITEON DVD RW LH20A1P WILL NOT WORK AT ALL
make a visual check of condition of controller board for bad soldering
Aug 21, 2008 | Computers & Internet
LiteOn DVDRW -LH20A1P This will play
G'day, sorry to say i've had the same problem with a few lighton drives and in the end we just stopped buying them, we had some luck upgrading the firmware, have a look here http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=75
Good luck
Terry
Mar 13, 2008 | Computers & Internet
Need Help!!!!!!!!!
by "disk", do you mean drivers? if so, go to this page: http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153 and select your drive model under "optical storage" and click search
Jan 20, 2008 | Lite On LITE-ON SOHW-1693SX BLACK RT...
Burning dvd data
its telling you that the dvd are not being closed, do you wait until the computer tells you its finished before you eject the disk, most lite on dvd's will eject themselves when done.
Dec 13, 2007 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
DVD/CD burner major problem
have you tried to use other blank dvd disk? maybe the blank disk that you are using have a defect.
Sep 23, 2007 | Lite On LITE-ON DVDRW 20X8X8X 20X6X8X 12X...
Computers & Internet Logo
56 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
