Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
System won't open programs and files
When i click on icons or try to change things on my control panel
i get a message that says
C:\windows\explorer.EXE application not found.
and
C:\windows\rundll32.exe application not found
and
also when i try to run things such as aol and other .EXE programs
it will ask what program i want to open it with.
I can not access my task manager either, it says application not found and whenever i go on the internet a message says that my desktop and folders are unaccessible
    Problem Solver:
You may have to reinstall Explorer is corrupted !. If you have a virus protection is your system make sure it is updated then scan your whole computer.You may have a virus in your system as well
Posted on Oct 12, 2008
  • pisseur Oct 13, 2008
    Make sure to scan your computer on a safe mode to have a better result. You would need also to make sure that the virus is not running in your registry.delete any rundll.exe you find on the local machine as well as on the current user.if anything seem to solve your issue just do in place update of windows to replace all the corrupted files. Goo luck !
.fxp is not an object file
For additional information click the following link: https://www.fixtoolbox.com/dbffix.html
DBF Fix Toolbox
Also you can try to follow these steps:
    1.Click on Start and then Control Panel. 2.Click on the Programs link.
    Note: If you're viewing the Small icons or Large icons view of Control Panel, you won't see this link. Click on the Default Programs icon and then click on the Associate a file type or protocol with a program link. Then proceed to Step 4.
    3. Click on the Make a file type always open in a specific program link under the Default Programs heading
    4. In the Set Associations window, scroll down the list until you see the file extension that you want to change the default program for.
    5. Click on the file extension to highlight it, once you've found the one you're looking for.
    6. Click the Change program... button above the scroll bar.
    The Open With dialog box should appear.
    7. Look through the options in the Recommended Programs area and choose the application that you want to open the file extension with when you double-click on the particular kind of file on your computer.
    Note: Chances are, the applications listed under Recommended Programs will contain the most applicable programs for this file type but be sure to look at the applications under Other Programs. You may need to click the v to expand the list of these programs.
    Note: Click Browse... to search through your computer for any program not listed that you'd like to use.
    8. Click the OK button on the Open With window. Windows 7 will refresh the list of file associations to show the new default program to open this type of file.
    9. Click the Close button at the bottom of the Set Associations window. You may also close the Control Panel window if it's still open.
    10. From this point forward, when you double-click on any file with this particular file extension, the program you associated it with in Step 7 will launch and load the particular file.
    Important: Whatever program used to automatically open when these types of files were launched will still open these types of files. To use another program, you'll just need to start the program manually and then browse your computer for the particular file.
Nov 12, 2015 | HiBase DBF Viewer 2000
Hi, Dave again - not sure if my problem was visible or not?
you may try to fix it by doing this:
http://www.sevenforums.com/tutorials/19449-default-file-type-associations-restore.html
If it does not help, reply and I will give you further instructions.
Mar 29, 2013 | Lenovo Computers & Internet
The problem is when click on application program it displays fatal error message of error opening driver file how can i fix this?
Is this happening on any program you click on? If so it means a virus has changed your program file associations.
Click Start/Control Panel/Accessories/System Tools/System Restore
When system restore opens select a date and time that was before this problem started happening. Let the system restore run to completion.
Don't worry, System Restore does not destroy any of your data, documents, music, pictures or videos. System Recovery destroys everything and sets the computer back to when you first purchased it.
If the virus won't let you start system restore then turn off your computer and turn it back on, start hitting the F8 key repeatedly until you see SAFE MODE. Select the safe mode option and when it boots up click Start/Programs/Accessories/System Tools/System Restore and from there select a date and time that was before you started having the problem.
If you still have a problem after doing the restore, report back and there is about 30 different little programs you will have to run to get your program file associations set back to their default settings.
Mar 21, 2012 | Computers & Internet
I did something to my pc now all my programs have the extension .ink and i cant run anything or open anything what can i do?
The .ink files are shortcuts. If they have no icon, or the same icon then you deleted the programs. Try reinstalling them. If not, don't worry, just launch you application by double clicking the .ink files. If it doesn't work no worries, that's not a biggie and can be easily fixed in a couple of minutes. There are a couple of ways to do it, read both:
Option 1:
- Go to Start -> "Control Panel" -> Click on Porgrams
- Click on "Default Programs"
- Click on "Associate a file type or protocol with a program." to open the "Set Associations" menu.
- Scroll through the list of extensions to locate the .lnk file extension. The listing will show the description and the current default program associated with it.
- Click on the extension (to select it) and then click on "Change Program."
- Select the program you would like to open *.lnk file types.
- Click on OK.
Option 2 (If Option1 fails):
Simply download following file, unzip it, and run it. It will make necessary changes to the registry. Restart the computer and it should be fine.
http://www.winhelponline.com/fileasso/lnkfix_vista.zip
Jun 17, 2011 | Microsoft Computers & Internet
I tried to download the latest version of itunes but for someone it wouldnt download and now my old itunes doesnt work either. When I click on itunes to open it up, a message box pops up reading...
It sounds like the download removed the existing software.
I would open control panel, then click add or remove programs, then click on itunes. see if there is a repair option with the installer. sometimes there is, but if not, then uninstall it, but keep your saved files.
Then re-install it, and when it sets up, it should still accept your old saved files. That way you don't have to recopy you music, games or videos
The 'error 2" is saying that when you clicked on the icon, there was no file remaining in your system that matched what the program was that was assigned to that icon.
You can find out what the program was, and its location by right clicking on the icon, and then click on properties.
Jan 24, 2011 | Computers & Internet
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
When installing OT5 the resolution goes out an I get error message saying it cannot locate the CD. I meet the system requirements. Not sure what to do to fix it.
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jan 04, 2010 | The Learning Company Oregon Trail 5th...
After installing QuickTime all links to other quit working
You can use the uninstalled that comes with quicktime or you can use add/remove program in the control panel.
Dec 16, 2009 | Apple QuickTime
hi. its purely a virus problem that prompts u from performing some actions in ur system. visit filehippo.com website. download AVG anti virus latest version scan ur computer. the problem wil get solved.
Jan 20, 2009 | Toshiba Satellite A105 Notebook
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
69 people viewed this question
Alun Cox
