Sony 32 inch crt tv
I have a sony trinitron 32 inch crt tv made in 1998 the picture needs to be rotated a little bit.......on the bottom of the screen when you see scores go by the bottom right is too low and the bottom left is a little high so the screen seems to need to be adjust a little counterclockwise.....i got into service menu but not sure which settting to change can you help me
the tv is great and has a great picture
thanks
  • dcxguy48080 Oct 13, 2008
    thank you i will try that
    what does a yoke look like??
    thanks
  • 8,617 Answers
On the neck of the picture tube you will see the large yoke. Loosen the srew slightly and just rotate the yoke assembly very little counterclockwise. That should correct your problem.
Posted on Oct 13, 2008
  • Sonny Berry
    Sonny Berry Oct 13, 2008
    Its the large coil with the copper wires wrapped around it. Its very large and has a screw clamp that secures it to the kneck of the picture tube. Just unplug the set then loosen the screw on the clamp and very slightly twist the yoke just a very little bit counterclockwise. About a 1/8 of a inch should be enough to straighten out the picture.
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My Sony trinitron model number kv32hs500 were is the
If you take the TV and lay it flat on its face, then you will be able to get the whole back cover off. Once the back cover is removed, and with the TV still on its face, there will be some a large circuit board sticking up in the air from what is normally the bottom of the TV. At this point you may want to tip the TV back onto its bottom (so the screen is showing again). Now, on the right side of the circuit board, near a couple things that look like large batteries sticking up, will be the two IC chips. They are about an inch long and maybe half an inch wide. They are only a couple inches from each other. Hope this helps you locate them.
Apr 10, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron picture turning green hues
Nowadays CRT's do not have good quality shadow masks anymore. After heating up a little they can give a so called "blooming" effect giving a blue an yellow leaf effect large over the screen. Reason nonparallelity in deformation of the shadow mask.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Apr 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Aug 18, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
