Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Regrigerator shows error code 1F
LFX25960ST LG FRENCH DOOR REFRIGERATOR
DATE OF PURCHASE 7-7-07
DELIVERED 7-13-07
ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT.
NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
  • 3 more comments
  • tr-6 Oct 13, 2008
    For a solution you told me what was wrong. I need to know how to make it work.
  • Anonymous Oct 14, 2008
    I bought the exact same fridge the same week as you and have had exactly the same issues. The first icemaker mechanically broke and would not make ice (would make ice but not harvest it). Had this replaced via warranty. Now I have ER IF and they had me unplug it for four hours and thaw out the ice maker fan.... no luck. Tried many times, didn't work. Also, about a month ago, the freezer quit working for about 12 hours. After cleaning up the mess, it was blowing cold again. They are extending my warranty for free and sending out someone to repair it. They say ER IF means a ice maker fan issue, I think it means for *******, because thats what I am for buying this fridge.
  • Dan Berkich Feb 08, 2009
    I have the same problem with a LFX25980ST. Where can I buy the fan motor so I can fix it myself? I have a feeling that you cannot buy them because they fail so often and they make more money by forcing you to call a service rep. I spent $2800.00 on this refrig 15 month ago and I am highly disappointed that it is failing this soon.
  • maineiac Mar 13, 2009
    I have the same fridge- purchased 8/07. Fridge is 1.5 yr old. The "ER IF" code appeared. We unplugged for 4 hrs. plugged back in and the error appeared again. It seems that there is a pretty consistent problem here and LG should be ashamed of itself for delivering poor quality on a rather expensive fridge. Any hints on how to fix this....?? Im pretty handy w/repairs.
    Thank You !!
  • tlasalle58 Mar 30, 2009
    ER IF appears on front panel. It stands for Icemaker Fan, which apparently does not operate when this error code is showing. Bought same model on July 4th, 2007 and in service Sept 2007. Had service techician out and he said it may be stuck relays in the control board. He tapped the board a few time and it worked...for a day.....then error code came back....and then left...and came back...you get the picture.
Owned the LFX25960st since 2008. In 2010 same problem ,no ice,roll bar did roll, no water in tray. Manually poured water into tray. It would only partially freeze.SOLUTION= Unplug fridge, empty freezer and thoroughly check back plastic wall inside freezer ,also check for sagging plastic ceiling . Upper left corner of back panel is ice fan motor (2 screws secure it).Do not remove them just yet or fan will drop down inside condensor area.
My back panel and ceiling had been warped and pulled away by cramming to much frozen food into top drawer. Causing ice fan misalignment with duct leading to ice tray in the door. An expensive fridge shouldnt be built this cheap. Only 1 phillips head screw secures the back panel. If you tackle this job = remove freezer door (ph. head on L and R drawer slide) then lift entire stainless door up 6 inches and pull away from fridge. REmove drawer slides on left. I didn't remove right side. Phillips head screw removed from top center of back panel,pull panel out ,(top edge pulling down and out).Panel will stop half way out. wires unplug from top left corner first.squeeze tab plugs on wires. panel out,,,check and repair foam around fan blower port. It is all about pressurized air blowing up thru ceiling thru tiny ductwork into ice tray.
Confirm that ice fan runs at a fast speed (sounds like bathroom vent fan)only smaller. Reassemble all. One more thing.Open left door. The 2 round air ports on left edge of fridge wall. The top port may be modified for increased air flow by removing center part of plastic grid-work with a utility knife. Bottom port not nesessary, for you want cold air flooding in,,,not out. Modify the top door port also (snip out the crosshatch rubber in the very center). Much more cold air into ice tray area. After all the quirky hassle of being an LG owner ,we really like it as of right now.
Posted on May 24, 2012
  • 750 Answers
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Posted on Oct 12, 2008
  • Neil Golan
    Neil Golan Oct 13, 2008
    Hello tr-6
    Being that you had the icemaker was already changed once before, and you are still having the same problem, I detect that you need an actual hands on diagnoses.
    This situation calls for a service call with an authorized tech who can be there physically in person for an on hands physical diagnoses.
    Our site does have sponsors who are experts in this field for you to choose from.
    My earlier explanation was meant to help you understand the problem.
    If not then keep this for your tech!
    Huuum
  • Neil Golan
    I'm sorry if this was not clear to you.
    It says there is a bad fan motor connection in tour icemaker!
    This is usually a call for the fan motor to be replaced.
    I suggest you have service do the job!!!!!!!!!
    Thank You for being so kind!
    Huuum
    ERROR CODE : I F
    Abnormality of
    BLDC FAN Motor
    for Ice Making
    seconds during BLDC
    FAN motor operating
    Remark
    Poor BLDC Motor
    TR
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
My LFX25960st LG stainless refrigerator ice maker isn't working, it'll make a few ice cubes every couple of days and now on the touchpad it says ER IF and i can't touch anything, how can i fix my problem?
Remove the fresh water hose coming into your refrigerator and check the water flow with a small bucket. This actually sounds like a replace water filter error. Some IF error codes break down to Inline Filter.
Jul 31, 2010 | LG LFX25960ST Stainless Steel French Door...
Not making ice error code 1f
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX23961SW Bottom Freezer French Door...
Error code er 55? I am not getting water into ice
There are several issues with this ref.
Ref. Lamp cover melting.
Department of energy rework.
Contact LG for service repairs are free.
Jan 04, 2010 | LG LFX25960ST Stainless Steel French Door...
Ice maker don't make ice and display code error
The ice fan is frozen. It is located behind the rear panel inside the freezer drawer. I had the same problem in November 2008 that was fixed under warranty. They replaced the fan and housing, and the panel duct assembly (both because a design revision provided a way to drain the water that was freezing the fan), and the main controller board (presumably because there was a new defrost program, but also because of the Energy Star settlement.) If your refrigerator is out of warranty, you can remove the freezer drawer to get at the panel behind it. Remove and defrost the fan housing. Drill some small holes in the bottom of the fan housing for drainage. Put it back together and see if that solves the problem.
Sep 07, 2009 | LG LFX25960ST Stainless Steel French Door...
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
LG Refrigerator model LFX25950SB
it means that the motor fan inside freezer the sends air to the ice maker is not communicating with mother board you have no ice right then you need either the motor fan or main board if you dont know howto trouble shoot you need a tech to come out
Oct 31, 2008 | LG LFX25960ST Stainless Steel French Door...
Error code 1F
ER IF means the icemaker fan is malfunctioning. Common cause is ice buildup in the fan shroud. LG has recently upgraded that shroud to drain off moisture that collects in there. The icemaker fan, when looking in the freezer, is the one on the left.
Very common for the icemaker itself to fail during the first year, have replaced many. They have since changed the design of it and it seems to have solved the problem.
May 16, 2008 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
686 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
