Question about GE Monogram ZDI15C Automatic Icemaker
GE Monogram Icemaker #ZDIS15CSS
Pump runs dry after several hours of running. water level in tank is lower then intake. When turning on unit, system fills up perfect, great pressure. it makes ice, but as soon as water drops pumps sucks air. seems like whatever tells it add water after initial start up is not working. anyone with sugguestion how to troubleshoot?
PS: i posted this several times, ubt it never seems like it takes. sorry if several
  • 1 more comment
  • jaycough Oct 13, 2008
    did all the easy stuff. unit is getting plenty of water and plenty of pressure. what ever tells it to add water after starting and after making a little ice. also none of my parts lists or the cut sheet tucked in the ice maker show a water snesor. Also if I could find a service manual i would buy one. if someone could point me into right direction, it has to be a sensor bin or termistor or circuit board..whatever controls the water after initial start is problem.. anyone?
    thanks..machine is spotless and no water restrictions. when ice maker turned on, the water tank is filled up quickly, recirc pump turns on and it recirc water to evap plate. after 1st sheet of ice is dropped to cutting grid, the water is not replenished, so as machine makes ice, the water tank gets low and pump sucks air. boils down to whatever tells it to add more water
  • Anonymous Mar 22, 2014
    Water continues to fill into the filler, but after it fills, it is not brought to the top of the machine which is were It makes ice. It just continues to start the filling cycle over and over again. it has been doing this, but if I turn off for a while it will start working again. this last time it went 13 days before it broke again.
    Brigadier General:
  • 6,966 Answers
Let's try the easy ones first:
  • check pressure incoming water supply (consistent between 30 & 120 psi;
  • check the supply filter if you have one installed;
  • try a reset, unplug from the mains for a couple of hours to dissipate residual power. Hopefully this will revert the unit back to factory defaults;
  • double check the water level sensor.
Other than the above, all other diagnosis and test would require opening the unit.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 13, 2008
    Top Expert:
  • GE Master
  • 77,201 Answers
All these machines use a sensor to regulate the flow of water to make ice, this is the weak part in the system, have it changed and the problem will be cured, I have first hand knowledge of this problem so I know the fix is correct.
Where is this sensor located?
Posted on Jan 05, 2010
    Scholar:
  • 121 Answers
Check that the pump is not over heating. 9 out of 10 ice machine calls that I go on is as simple as cleaning the machine. You can get a nickel safe ice machine cleaner from an appliance parts store. Remove the front cover and you'll see the pump and water fill. There is a switch for the machine that goes from on/off/clean. Switch to clean position and you see the machine dump the water. Once the water dumps add 5 to 7 ozs. of the cleaner and allow to run in cleaning mode for 15 min.. While cleaning the machine check water filter and inlet orifice to make sure they not obstructed. There is also a knob on the side of the inlet orifice that can be removed to show a screen that can be dirty. Also, you will probably see alot of slime build up that you will want to wipe off. Once you've cleaned the machine dump out the first 3 or 4 batches of ice that it produces, because it will have the chemical residue in it.
GE Automatic Icemaker Model ZDIS15CSSF, won't make ice.
These units often have a hard-to-see reset button to resume proper operation. Look hard or check your manual.
Jun 22, 2015 | GE Monogram ZDI15C Automatic Icemaker
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
Does this ice maker need a pump or is it built in zdis15css
It has a circulation pump that continuosly supplys water over a plate that forms a slab of ice on it. As the slab gets thicker the resistance values change in the ice and the machine opens a hot gas solenoid operated valve which floods the plate with heat from the condenser below. This makes the slab slide down the shoot onto a wire grid that is heated. The slab is cut into tiny little cubes and drops off into the ice bin. So yes the machine has a circulator pump. Ever so often you need to put it into the clean mode and add some nickleguard or ice machine cleaner to keep the pump and its components all happy happy.
Jun 13, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ge monogram ice maker makes loud churning noise. Any suggestions
Mine has been doing the same thing and foound it was the pump cavitating (dry). What caused it on my unit is there was buildup of minerals on the sides of the freezer plate so the ice slab wouldn't slide all of the way down onto the grid. When the unit would start the next cycle the water would ramp up over the stuck slab and down into the ice bin and then the pump would start making the noise. A related problem could be the cutter grid not heating so the slabs back up and results in the same issue. Look up into the freezer plate next time it makes the noise and see if there is a slab partially stuck.
Jun 12, 2009 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
We accidently left the freezer door open during the entire night and now icemaker doesn't dispense on monogram refrigerator, even though ice maker makes ice.
you might want to turn the whole fridge off (remove the food to a safe place) and let the fridge defrost, wipe any water up and retry. If it is under warranty, call GE
Nov 26, 2008 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram Won't Drain completely
the drain was clogged. A handyman used a snake to clean it out.
Apr 04, 2008 | GE 24 in. Monogram ZBD6880KSS Stainless...
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Ge monogram zd115c automatic icemaker not making ice
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
Nov 04, 2007 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZDI15C Automatic Icemaker Logo
3,314 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
