Question about Philips Magnavox MRD20037 System
No sound on Any Speaker
I Have a MRD20037 Magnavox home theater, perfectly wired and installed and yet theres no sound on any speaker
  • 659 Answers
Magnavox would suggest the following as would I
  • Increase the speaker volume
  • Disconnect the headphones
  • Switch on the selected source or select another source
  • Reconnect the speakers
  • Change and play another disc
  • Swap speaker connections
Posted on Oct 12, 2008
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
Convert speaker wire
just bring RCA connectors from market and connect one wire in the center of each and one common to the both.
rate the solution pl.
Sep 17, 2009 | Philips Magnavox MRD500VR System
How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Jun 02, 2009 | Philips MX6050D System
Lengthen speaker cable
i had same problem. yeah, there's not much wire included. i just purchased a spool of speaker wire and got the length i needed. since the wires are usually color-coded, i tagged each new wire with 2 stick-on-spots, with sticky side back to back over the wire, and wrote RR & LR to make it easier for locating them in a jumble. you can also just splice and tape extra wire on but i feel every cut cuts back on quality of sound.
May 27, 2009 | Montgomery Ward Audiovox DV1201 Theater...
Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Jan 28, 2009 | Philips HTS-3565 Theater System
The difference between (+) and (-) on my speaker
The one with the black stripe is the negative.
Cheers!
Nov 23, 2008 | Philips Magnavox MRD510/17 Theater System
Extension speaker wire
Radio Shack is you're best bet. They have several different types of speaker wire. That is where I get most of my audio and video supplies.
Aug 25, 2008 | Panasonic Home Theater System System
Philips Magnavox MRD20037 System Logo
132 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
